Engine Bar - X89K Casa Flat one Side Bar
Postby DaveTomo » Sat Feb 16, 2019 6:19 pm
Anyone used one of these ? Just after a bit of feedback,
1) once in do they move at all?
2) straight forward to fit? and fit OK?
I've seen the install video, seems easy enough - just after some real world experience of them.Appreciate your help
DaveTomo
Re: Engine Bar - X89K Casa Flat one Side Bar
Postby dscscotty » Sat Feb 16, 2019 9:32 pm
Fitted several, use them in my race scooters, fantastic bit of kit, I'm not a lover of the original off set, but these are the biz!
Postby Fast n Furious » Sun Feb 17, 2019 4:00 am
There is a lack of clarity with this product.
It's advertised as suitable for S1, S2, S3, GP and Serveta.
Innocenti changed the Cone design back in 62 when they moved over to the larger silentblock mounting design.
So, I suspect it will fit either the earlier or the later frames but not both.
Can anyone clarify?
Postby modster79 » Sun Feb 17, 2019 8:10 am
Fitted in my series 1, Indian engine casing, seemed a bit tight when initially fitting with the casing being tight to the cones, but when in movement and spacing okay.
modster79
Postby dscscotty » Sun Feb 17, 2019 9:09 am
Yes the cone angles are different, my use has been stricthly S3-
Postby HxPaul » Sun Feb 17, 2019 9:28 am
Surely the cone angles are the same,they just changed the cones from short engine bar(small engine mounts).To long engine bar(big engine mounts)The Lambretta shops ie. Scooter Restorations etc.only sell
these cones,they dont mention the angles.
Postby Mag » Tue Feb 19, 2019 11:20 pm
recently fitted the casa bar to my TS. Wouldn't dream of going back to off set cones.
Mag
Postby roli150lam » Wed Feb 20, 2019 10:54 pm
I have two of these engine bars,the cones tho protrude from the tube by 4mm each side of the tube,thus making it impossible to fit the engine.I have tried tapping the cones flush with the tube,this closes the cone meaning the bar will not slide thru.
I spoke to the supplier 10 days ago,they were surprised but agreed to send replacement cones.I am still waiting for the cones to arrive.
So my experience is I have a problem and am waitng for a solution to be reached.
So I couldn't recommend them yet.
Are there different cone angles?Have the cones I have been machined wrong?Am I doing something wrong?
roli150lam
Postby HxPaul » Wed Feb 20, 2019 11:28 pm
HxPaul wrote:Surely the cone angles are the same,they just changed the cones from short engine bar(small engine mounts).To long engine bar(big engine mounts)The Lambretta shops ie. Scooter Restorations etc.only sell
Read this post.
Postby Fast n Furious » Thu Feb 21, 2019 12:40 am
roli150lam wrote:I have two of these engine bars,the cones tho protrude from the tube by 4mm each side of the tube,thus making it impossible to fit the engine.I have tried tapping the cones flush with the tube,this closes the cone meaning the bar will not slide thru.
What frame are you trying to fit this to Roli?
Postby roli150lam » Thu Feb 21, 2019 5:53 am
2xLI125Special frames.1965&1966.Offset cones i've used fit flush to the tube as do the original type cones.
roli150lam
Postby roli150lam » Thu Feb 21, 2019 7:07 am
Read this post.
I did.
roli150lam
Postby DaveTomo » Thu Feb 21, 2019 7:08 pm
Well I bit the bullet and bought the Casa bar - all good, a little bit tight compared to the 50 odd year old cones they were replacing (to be expected I suppose) but went in OK and lined up- appreciate the feedback chaps.For reference SX150 frame
Roli150lam hope you get yours sorted mate
DaveTomo
Postby roli150lam » Thu Feb 21, 2019 7:38 pm
DaveTomo wrote:Well I bit the bullet and bought the Casa bar - all good, a little bit tight compared to the 50 odd year old cones they were replacing (to be expected I suppose) but went in OK and lined up- appreciate the feedback chaps.For reference SX150 frame
Thanks,me too.
I don't want to be hammering the bar thru,defeats the purpose of the cones imo.
roli150lam
Postby martyn dwane » Wed Feb 18, 2026 10:39 pm
reviving this thread,
just tried to fit the above cones and bar, cones protrude both sides of the frame tube too much to fit the engine into the frame. Frame is Italian GP125,1970.
then tried in to my Li150 frame hanging in the workshop same problem, then tried in my Li150 series 3 frame same again.
Was there ever a problem with a batch ?
Bought around 18/24 months ago.
Looks like i may have to get them machined down somewhere ,unless someone can suggest another solution.
thanks in advance.
martyn dwane
Postby Storkfoot » Thu Feb 19, 2026 12:44 pm
martyn dwane wrote:reviving this thread,
thanks in advance.
I had to have a set machined down too. I never tried to find out whether there was a batch problem.
Postby Adam_Winstone » Thu Feb 19, 2026 7:24 pm
I had the same too, ended up grinding them down to suit.
Users browsing this forum: Baidu [Spider] and 55 guests
