New gear boxes
New gear boxes
Postby Scooterlam » Sat Mar 03, 2018 12:00 pm
Hi guys.
What's the percentage difference between 4th and 5th on the 5 speed boxes and does any one know 3rd to 4th on an Italian li box.
I think Indian GP is 19% 3-4.
Scooterlam
Re: New gear boxes
Postby hullygully » Sat Mar 03, 2018 12:04 pm
whose 5 x speed gearboxes?
A/F's?
Broady's?
Cyclone?
Omega / RS?
Re: New gear boxes
Postby hullygully » Sat Mar 03, 2018 12:08 pm
LI150 3rd to 4th jump is 23%
correct with indian GP200
Re: New gear boxes
Postby Scooterlam » Sat Mar 03, 2018 12:18 pm
hullygully wrote:whose 5 x speed gearboxes?
A/F's?
Broady's?
Cyclone?
Omega / RS?
All of them :D
Maybe not the omega.
Be good to have an easy reference.
Most of us , I guess ore most interested in the last step.
Scooterlam
Re: New gear boxes
Postby holty » Sat Mar 03, 2018 12:42 pm
im just fitting an afclose 5 box, they come with 2 options for 5th gear, either 12 percent or 9 percent, you choose which will suit your engine performance, heres a pic of all the ratios
ImageUntitled by stephen holt, on Flickr
holty
Re: New gear boxes
Postby Scooterlam » Sun Mar 04, 2018 12:11 pm
Thanks good.
So much easier with it all in one place.
Scooterlam
Re: New gear boxes
Postby Watfordwhite » Sun Mar 04, 2018 1:58 pm
Holty, what difference would you get between the alternative 5th gear on the AF.
Would one work as almost an overdrive, and the other as a real 5th gear?
What sort of top speed increase could you expect from both?
Sorry my knowledge on gear box settings is non existent
Watfordwhite
Re: New gear boxes
Postby ULC Soulagent » Sun Mar 04, 2018 6:52 pm
ULC Soulagent
Re: New gear boxes
Postby Scooterlam » Sun Mar 04, 2018 10:52 pm
Watfordwhite wrote:Holty, what difference would you get between the alternative 5th gear on the AF.
The awnser to any of the questions would depend greatly on the characteristics of the engine.
Scooterlam
Re: New gear boxes
Postby holty » Mon Mar 05, 2018 6:37 pm
scooterlam is correct the power delivered by the engine will dictate what ratio it will pull, as does the weight of the scooter and rider, also remember that as you go faster there is more drag to slow you down, you should be able to use either if you get your final drive ratio correct, remembering that your choice of exhaust will dictate your final drive ratio. i prefer an expansion exhaust which gives a powerband, the idea is that when you change up to the higher gear you are still in the powerband and it will pull in that higher gear.
holty
Re: New gear boxes
Postby Watfordwhite » Mon Mar 05, 2018 8:42 pm
Ok, so I have a SIL GP200 lump and gear box with 225 Rapido 28mm Delorto (reed valuve ) and a MB MK3 clubman. I am approx 13 st and the bike is an S2 full panel work. Buy adding the AF 5 speed would this add anything to the top end?
I refuse to pay £1000 for the Cyclone so the AF is a reasonable cost in comparison.
Our club usually ride around the 45-50mph mark. Which is a little slow for my liking. Local rides only. The Rapido is not set up right and is currently being looked at. Now is the time if any to add that gear box. Is it worth the additional £500. + fitting costs?
We have a few long distance rides planned for Europe this year. This bike is built for high speed touring and that's what I want. Will this help? If so how. Better top end, or more relaxed cruising. (Overdrive, for those old enough)
Watfordwhite
Re: New gear boxes
Postby ULC Soulagent » Mon Mar 05, 2018 10:49 pm
I’m currently building an RT 230 reed setup breathing through a 25 delly and farting out a bgm v3 clubby.
Using a SX200 G/B 15/46 4.8 FD
So going by your setup I’d say the af 5 with the 35 tooth would suit it nicely @ 4.81 fd
ULC Soulagent
Re: New gear boxes
Postby bike grim » Mon Mar 05, 2018 11:13 pm
Sounds a bit sensible that Shane?
Re: New gear boxes
Postby Fast n Furious » Tue Mar 06, 2018 3:34 am
Watfordwhite wrote:Ok, so I have a SIL GP200 lump and gear box with 225 Rapido 28mm Delorto (reed valuve ) and a MB MK3 clubman. I am approx 13 st and the bike is an S2 full panel work. Buy adding the AF 5 speed would this add anything to the top end?
If you find yourself constantly dropping down to third to keep the engine in the power band then the right 5 speed box would help here. I have this fight a lot on country roads on my TS1, especially when riding into the wind. I'm considering a 5 speed box to try and make it work just as well on the country roads as it does on the motorways.
If your tuning is more on wide band grunt, then its less attractive unless you're 2 up and laden.
The MB and AF boxes are more suited to the narrow power band engines and the CML / Cyclone would be more suited to a tune more wide banded and torquey.
Re: New gear boxes
Postby ULC Soulagent » Tue Mar 06, 2018 12:29 pm
bike grim wrote:Sounds a bit sensible that Shane?
It is Gareth but just want reliability this year instead of going flat out all the time and destroying my engines like last year :lol:
ULC Soulagent
Re: New gear boxes
Postby bike grim » Tue Mar 06, 2018 1:52 pm
:roll:
Re: New gear boxes
Postby Scooterlam » Tue Mar 06, 2018 6:59 pm
:roll:
The two arnt mutually exclusive. :twisted:
Scooterlam
Re: New gear boxes
Postby hullygully » Tue Mar 06, 2018 7:49 pm
A/F's?
Broady's?
Cyclone?
Omega / RS?
All of them :D
booooo whats wrong with the Omega, it goes ggreat with my Gori...........
I've a broady early 5-speed in my TS1 230, based the final drive on my previous LI150 gearbox, but with a smidgen of overdrive
Re: New gear boxes
Postby Watfordwhite » Tue Mar 06, 2018 8:54 pm
Ok so Cyclone way over priced
Omega bad reviews
AF sounds good, good price (well better)
Anybody has anything to say about the Broady 5 speed? Wow, just seen the price on that. Boy thought the cyclone was dear
Watfordwhite
Re: New gear boxes
Postby Tractorman » Wed Mar 07, 2018 9:40 am
Should like to try one of these in the combo but £500 is a costly experiment if it does not live up to expectations. Pity they don't have a demo gearbox you can try for a week or so.
Users browsing this forum: No registered users and 49 guests
