hullygully wrote:whose 5 x speed gearboxes?
A/F's?
Broady's?
Cyclone?
Omega / RS?
Untitled by stephen holt, on FlickrWatfordwhite wrote:Holty, what difference would you get between the alternative 5th gear on the AF.
Would one work as almost an overdrive, and the other as a real 5th gear?
What sort of top speed increase could you expect from both?
Sorry my knowledge on gear box settings is non existent
Watfordwhite wrote:Ok, so I have a SIL GP200 lump and gear box with 225 Rapido 28mm Delorto (reed valuve ) and a MB MK3 clubman. I am approx 13 st and the bike is an S2 full panel work. Buy adding the AF 5 speed would this add anything to the top end?
I refuse to pay £1000 for the Cyclone so the AF is a reasonable cost in comparison.
Our club usually ride around the 45-50mph mark. Which is a little slow for my liking. Local rides only. The Rapido is not set up right and is currently being looked at. Now is the time if any to add that gear box. Is it worth the additional £500. + fitting costs?
We have a few long distance rides planned for Europe this year. This bike is built for high speed touring and that's what I want. Will this help? If so how. Better top end, or more relaxed cruising. (Overdrive, for those old enough)
bike grim wrote:Sounds a bit sensible that Shane?
ULC Soulagent wrote:bike grim wrote:Sounds a bit sensible that Shane?
It is Gareth but just want reliability this year instead of going flat out all the time and destroying my engines like last year
bike grim wrote:ULC Soulagent wrote:bike grim wrote:Sounds a bit sensible that Shane?
Scooterlam wrote:hullygully wrote:whose 5 x speed gearboxes?
A/F's?
Broady's?
Cyclone?
Omega / RS?
All of them![]()
Maybe not the omega.
Be good to have an easy reference.
Most of us , I guess ore most interested in the last step.
