Phil D wrote:The Citroen garage is near the hotel ibis in Belfort.
Garage Gresti. On the D83 as WT says they may have some NOS studs.
Angry Bloke wrote:Is it on the repaired side of the flange ? If so I wouldn't try bending it back insitu
Neither you or Colin got a m7 , kickstart bolt or inlet long bolt ?
Warkton Tornado No.1 wrote:If you can nick the lower damper fixing out of the link from yours (or anybody elses!) forks you might be able to use that as they are also M7....
Users browsing this forum: Google [Bot] and 76 guests
