Stud in France
Stud in France
Postby Storkfoot » Mon Jun 05, 2017 8:52 pm
Long story but limping home from Eurolambretta. Currently in Belfort, France.
I have a GT186 which, after a prang with an Italian petrol station pothole, has a bent exhaust stud. This is preventing a good seal and I have blown one gasket.
Thinking of taking the stud out in the morning, putting nuts on either end, and hitting the middle to straighten it.
Anyone any better ideas beyond trying to get to a precision engineer who can make one up at M7!!
Re: Stud in France
Postby Phil D » Mon Jun 05, 2017 9:09 pm
If you could get access to a vice the nut on either end of the stud to protect the thread may straighten it enough
to get you home .
Phil D
Re: Stud in France
Postby Warkton Tornado No.1 » Mon Jun 05, 2017 9:10 pm
Citroen used M7 fasteners. I know this link is UK based but it might help you make a French mechanic understand:
http://shop.citroenclassics.co.uk/m7-st ... 1219-p.asp
Re: Stud in France
Postby Phil D » Mon Jun 05, 2017 9:24 pm
The Citroen garage is near the hotel ibis in Belfort.
Garage Gresti. On the D83 as WT says they may have some NOS studs.
Phil D
Re: Stud in France
Postby Storkfoot » Mon Jun 05, 2017 9:27 pm
Thanks. I'll see what I can sort in the morning and report back, hopefully not having seized on the way to Hook of
holland.
Re: Stud in France
Postby Storkfoot » Mon Jun 05, 2017 9:28 pm
Phil D wrote:The Citroen garage is near the hotel ibis in Belfort.
Brilliant. Nice work Clouseau ;)
Re: Stud in France
Postby Wack » Mon Jun 05, 2017 9:33 pm
Screw two nuts on the stud and slip an 11mm socket over both ,then with an extension bar gently bend the stud back.
Re: Stud in France
Postby Angry Bloke » Mon Jun 05, 2017 9:53 pm
Is it on the repaired side of the flange ? If so I wouldn't try bending it back insitu
Neither you or Colin got a m7 , kickstart bolt or inlet long bolt ?
Angry Bloke
Re: Stud in France
Postby Storkfoot » Mon Jun 05, 2017 10:16 pm
Angry Bloke wrote:Is it on the repaired side of the flange ? If so I wouldn't try bending it back insitu
It's not the welded side and, no, neither of us have anything suitable, sadly.
I am still wary of trying anything in situ given that the exhaust flange has already been welded after this altercation with a pothole.
Re: Stud in France
Postby Warkton Tornado No.1 » Mon Jun 05, 2017 10:27 pm
I've just had another thought :roll:
If you can nick the lower damper fixing out of the link from yours (or anybody elses!) forks you might be able to use that as they are also M7....
Re: Stud in France
Postby Chadley » Mon Jun 05, 2017 11:58 pm
Warkton Tornado No.1 wrote:If you can nick the lower damper fixing out of the link from yours (or anybody elses!) forks you might be able to use that as they are also M7....
...or a frame leg bolt that are also m7.
Chadley
Re: Stud in France
Postby Storkfoot » Tue Jun 06, 2017 11:00 am
Managed to get access to a vice on the campsite. Put the brass nuts on either end and a socket as a pivot. Straightened it :D Scoot all back together and ticking over nicely. Thanks again.
Re: Stud in France
Postby bike grim » Tue Jun 06, 2017 11:09 am
Well done. Good luck.
Re: Stud in France
Postby Phil D » Tue Jun 06, 2017 11:33 am
8-)
Phil D
Re: Stud in France
Postby Angry Bloke » Tue Jun 06, 2017 11:39 am
Excellent 8-)
Angry Bloke
Re: Stud in France
Postby Fast n Furious » Wed Jun 07, 2017 1:12 am
Perseverance.....You've gotta love it. :)
Re: Stud in France
Postby kennystag » Thu Jun 08, 2017 6:56 am
Magic,
Glad you are now feeling very happy.
Stag
8-)
kennystag
Re: Stud in France
Postby Storkfoot » Thu Jun 08, 2017 10:41 am
Well it's got me back to Cambridge Services so far. What could go wrong in the last 200 miles?
Please don't feel the need to answer that !
Re: Stud in France
Postby Mel K » Thu Jun 08, 2017 10:42 am
Good luck Paul :D no better feeling riding there and back in one piece .
Mel K
Re: Stud in France
Postby Adam_Winstone » Thu Jun 08, 2017 11:53 am
Just another chapter in the tale, making for a better story :)
Users browsing this forum: Charliescooter and 214 guests
