Paulnobodyimportant wrote: But wont that mean that there is power to the speedo whilst the scooter is sat in the garage or is this OK. Plus from reading the forums, I take it that i connect the RPM brown wire direct to the yellow wires from the stator, before it enters the wassell unit.
If connecting direct to the battery is bad news, then I can always run a wire back up the frame and connect to the lighting power feed. This means that when the ignition is off, there is no power to the speedo.
Paul
