Paulnobodyimportant wrote: But wont that mean that there is power to the speedo whilst the scooter is sat in the garage or is this OK. Plus from reading the forums, I take it that i connect the RPM brown wire direct to the yellow wires from the stator, before it enters the wassell unit.
If connecting direct to the battery is bad news, then I can always run a wire back up the frame and connect to the lighting power feed. This means that when the ignition is off, there is no power to the speedo.
Paul
Users browsing this forum: nsaints and 50 guests
