Wack wrote:You could try marker pen on the linings then fit hub and tighten up. Spin the wheel and push the brake arm on at the same time to rub the ink off. Very often only one shoe touches the hub usually the bottom one. If so, fit a thin plate under the cam plate on the top shoe and try again. I have an old hub with windows cut in to check with a feeler gauge.
