Rear brake problem
Rear brake problem
Postby Covboy » Sun Nov 01, 2015 2:31 pm
Ok this is a weird one.....
Back brake is adjusted so that even a light/ minuscule press of the foot pedal activates the pads.
Stationary, with the foot pedal depressed it's impossible to move the scoot, forward of backward- the brakes lock firm
But.....when traveling, even at low speeds the rear brake does not function, even when pressed very hard....
Any ideas chaps????
Re: Rear brake problem
Postby Adam_Winstone » Sun Nov 01, 2015 3:44 pm
SIL 200 casing?
Postby Scooter Paul » Sun Nov 01, 2015 4:11 pm
Have you checked the routing of the cable? Could it be that when you have weight on the scooter and the engine pivots upwards with suspension movement the cable adjustment alters in some way?
Paul
Scooter Paul
Postby Covboy » Sun Nov 01, 2015 5:02 pm
Hi guys
Yes SIL 200 casing...
Ref cable routing- routed in the normal way..as OP, works OK with rider weight when stationary
Postby bazza3004 » Sun Nov 01, 2015 5:17 pm
I think some of the later casings had the brake cam hole machined slightly out. Not sure how old your case is and if it may be affected by this.
bazza3004
Postby MickYork » Sun Nov 01, 2015 6:20 pm
With the SIL casings it's hit and miss as to whether the back brake works or not. The problem is caused by the brake shoe pivots being slightly mis-aligned. This can cause only part of the brake shoe to work and one brake shoe catching before the other.
There are 2 common solutions; use a Jockeyboxenstop (probably spelt wrong !!) rear brake kit which allows the brake shoes to be adjusted to suit......good luck setting them up !!
The second option is to get the existing brake shoes skimmed to suit. AF did this for my mate and they charged £20 including new brake shoes. He drove the scooter there and they did the job in less than half an hour. Top service and £20 well spent.
Postby Covboy » Sun Nov 01, 2015 11:19 pm
Thanks mick
Does anyone know where the brake skimming can be done in the Midlands??
Thanks all
Steve
Postby Wack » Mon Nov 02, 2015 6:51 pm
You could try marker pen on the linings then fit hub and tighten up. Spin the wheel and push the brake arm on at the same time to rub the ink off. Very often only one shoe touches the hub usually the bottom one. If so, fit a thin plate under the cam plate on the top shoe and try again. I have an old hub with windows cut in to check with a feeler gauge.
Postby drivera » Mon Nov 02, 2015 7:05 pm
Wack wrote:You could try marker pen on the linings then fit hub and tighten up. Spin the wheel and push the brake arm on at the same time to rub the ink off. Very often only one shoe touches the hub usually the bottom one. If so, fit a thin plate under the cam plate on the top shoe and try again. I have an old hub with windows cut in to check with a feeler gauge.
Ditto , done this on a few mates scooters , works a treat :)
drivera
Postby Covboy » Mon Nov 02, 2015 7:16 pm
Thanks All - will try this weekend (hopefully) and post result in this forum
Postby Dimitrios_231 » Mon Nov 02, 2015 9:16 pm
I've cut an old Spanish hub to help me skimming the brake shoes,
I had checked it first,for being true round on the inside.
I'll weld in the near future an adapter to attach the blades.
Dimitrios_231
Postby Wack » Mon Nov 02, 2015 10:19 pm
I had an original skimming tool unfortunately it was broken but the "blades" were what looked like segments cut from a course metal file and were adjustable via screws. It will be interesting to see yours done.
Postby Dimitrios_231 » Mon Nov 02, 2015 11:23 pm
Dimitrios_231
Postby hullygully » Wed Nov 04, 2015 11:20 am
got my brake shoe trimmer tool from scooter restorations complete with vega / starstream adaptor some years ago
Postby Covboy » Wed Nov 18, 2015 6:26 pm
Gransport fixed it for me
3 main problems contributing to the issue
Rear brake cable routed incorrectly (over carb manifold, outer not fitting properly ) :oops:
Very hard Italian shoes. Softer compound shoes fitted
SIL casing pivots misaligned. Rewelded to provide correct pivot profile.
So I have a useable brake now.
Postby kalifornia » Mon Feb 08, 2016 6:56 pm
How much did they charge for that service Covboy? If its down to the pivots being mis-alligned, I'd rather get the casings rewelded and made good so its not an issue every time brake shoes are replaced.
kalifornia
Postby Dimitrios_231 » Tue Apr 12, 2016 2:15 pm
I forgot to add pics,sorry,
at the end,I tapped 3 holes to secure the 'homemade' blade.
Different heights can be used for different applications,
sometimes new brake shoes are too fat to fit a hub,
sometimes new brake shoes need re-profile,
sometimes worn shoes just need re-profile,
sometimes ... :)
Dimitrios_231
Users browsing this forum: Google [Bot] and 50 guests
