It was in the Fine Young Cannibals' "Good Thing" video
it is being redone as close as possible to the original build
shame all we have to go on is the black & white footage...
would love to see a colour photo of this from back then...
would appreciate that, thanksjustbretta wrote:I know I have a couple of pics of this scooter that I took at a custom Show in Bogor Regis/Worthing way at the back end of the 80's. Ill dig them out and scan them on here if their of any use to you.
same here, but Ithink this one will have the right lookcitydaz wrote:I dont usually like cut-downs / skellys, (waste of good italian engineering and all that), but there something about this scoot I really like.
with some difficulty I imagine... there are already holes and entry pipes welded to the frame. I have threaded some cables through, just not all of them at the same time... but only wanted to do that job once.Andie wrote:...do the throttle, gear change and clutch cables all run through the frame? If so, how do you run them though initially?
cheers for the tip, there is some wire through some of the holes, hopefully the painter will leave it there...mark1 wrote:The best way I've found to thread cables through the frame is to get some MIG welding wire, bend over one end into a hook and thread it through the frame (....
Users browsing this forum: Baidu [Spider] and 138 guests
