"Good Thing" cutdown
Postby byron » Sat Nov 21, 2015 5:31 pm
did a rough dry build on this yesterday
It was in the Fine Young Cannibals' "Good Thing" video
it is being redone as close as possible to the original build
shame all we have to go on is the black & white footage...
would love to see a colour photo of this from back then...
byron
Re: "Good Thing" cutdown
Postby Scarborough Col » Sun Nov 22, 2015 6:16 pm
Good project mate.. I remember the video well.. It was played repeatedly in the Long Bar @ the Gt Yarmouth National rally 1989...
I know the video was in black and white, but I would say the scooter was all white, frame forks hubs rims cowlings the lot...
if not white, certainly a very light colour...
Scarborough Col
Postby Andie » Sun Nov 22, 2015 8:10 pm
excellent project, good luck - nice to have a bit of history involved.
can't get the youtube share link to work... but this is the link for others - 1.06
https://www.youtube.com/watch?v=xrOek4z32Vg
http://i157.photobucket.com/albums/t68/ ... 0thing.jpg
Hope it goes well. I'm planning on doing a chop next year, obvs I'll be looking for a frame that one of my mates took a hacksaw too, and not a complete one.
Andie
Postby byron » Mon Nov 23, 2015 10:21 am
^that's the bike!
it was almost completely "white", which, I'm told by a former owner that saw this on facebook, is actually a pearl white, with red flip flop over. Got to get one of those headlamps for it!
byron
Postby justbretta » Mon Nov 23, 2015 11:31 am
I know I have a couple of pics of this scooter that I took at a custom Show in Bogor Regis/Worthing way at the back end of the 80's. Ill dig them out and scan them on here if their of any use to you.
justbretta
Postby byron » Tue Nov 24, 2015 10:53 am
justbretta wrote:I know I have a couple of pics of this scooter that I took at a custom Show in Bogor Regis/Worthing way at the back end of the 80's. Ill dig them out and scan them on here if their of any use to you.
would appreciate that, thanks
byron
Postby byron » Mon Dec 14, 2015 8:08 pm
dry build done, that headlamp looks the part.
strip it down tomorrow, ready to go off to paint
the header pipe was a bit tricky to mock up, having no starting point on the pipe location, other than that black & white still captured from the video, but it's there now, tacked in place, needs welding around properly. so far, so good...
byron
Postby LateAgain » Tue Dec 15, 2015 10:07 pm
Quality. Spirit of the 80s alive and well.
LateAgain
Postby Andie » Fri Dec 18, 2015 7:56 pm
Looking forward to seeing how this progresses; do the throttle, gear change and clutch cables all run through the frame? If so, how do you run them though initially?
Andrew
Andie
Postby citydaz » Fri Dec 18, 2015 9:30 pm
I dont usually like cut-downs / skellys, (waste of good italian engineering and all that), but there something about this scoot I really like. :)
citydaz
Postby byron » Sat Dec 19, 2015 4:05 pm
citydaz wrote:I dont usually like cut-downs / skellys, (waste of good italian engineering and all that), but there something about this scoot I really like. :)
same here, but Ithink this one will have the right look
Andie wrote:...do the throttle, gear change and clutch cables all run through the frame? If so, how do you run them though initially?
with some difficulty I imagine... there are already holes and entry pipes welded to the frame. I have threaded some cables through, just not all of them at the same time... but only wanted to do that job once.
It's gone off to paint today. I have sourced a switch, and got main /dip functionality on that headlamp, so waiting for parts on this one just now...
byron
Postby mark1 » Thu Dec 24, 2015 12:18 pm
The best way I've found to thread cables through the frame is to get some MIG welding wire, bend over one end into a hook and thread it through the frame (go from the engine up to the steering coloum) When the hooked end of the wire is at the steering colum get another piece of MIG wire with a hook bent on to it and pull the wire through the hole.
When the wire is running through the frame run the cable outer through the wire and hey presto your cable is threaded through the frame.
mark1
Postby byron » Sat Dec 26, 2015 6:52 pm
mark1 wrote:The best way I've found to thread cables through the frame is to get some MIG welding wire, bend over one end into a hook and thread it through the frame (....
cheers for the tip, there is some wire through some of the holes, hopefully the painter will leave it there...
byron
Postby byron » Tue Feb 16, 2016 3:14 pm
it's painted...
and engine is built; rearsets, brake etc sorted
I did use a vespa brakelight switch there, but that's better than an in-line one, or one of those universal spring affairs.
just got to put it all back together now...
byron
Postby Dazts1 » Thu Feb 18, 2016 12:27 am
Looking forward to seeing this built. Looks cool.
Postby LateAgain » Fri Mar 04, 2016 12:18 am
Good stuff, like the rearset set up.
LateAgain
Postby byron » Wed May 04, 2016 6:16 pm
sorry, never put any pics up of the finished bike!
hopefully, will be at Flying 8 Balls rally in sunny norfolk this weekend
byron
Postby Toddy » Wed May 04, 2016 9:23 pm
Nice job , look forward to seeing it in the sunshine 8-)
Postby Andie » Sun May 08, 2016 6:45 pm
That looks very smart. nice restoration and history behind it.
Andie
Postby SlackerThePinstriper » Sat Jan 07, 2017 5:24 pm
Do the pictures not work? Or is it just me?
Love this and love the vid to Good Thing. A big inspiration on me and my Lammy build.
Can't wait to see this done
Users browsing this forum: No registered users and 126 guests
