The Ginger Stepchild....
Re: The Ginger Stepchild....
Postby roli150lam » Mon Jan 04, 2016 11:43 am
Copper mallet will do it.
roli150lam
Postby LateAgain » Sat Jan 09, 2016 12:39 pm
Legshield beading on, bit of extra trimming to the leggies req'd, showed up a couple of lumps and bumps.
400x10s on front and back, look massive. Will need to shave the bumpstop on the case I'm using.
Floating front muddy next
LateAgain
Postby Noddabodder » Sun Jan 10, 2016 9:20 am
Great build, I really like the proportions on this. What exhaust/engine configuration are you planning?
Noddabodder
Postby AdiD63 » Sun Jan 10, 2016 4:24 pm
Fantastic, really enjoying seeing this build come together.
AdiD63
Postby gaz_powell » Sun Jan 10, 2016 7:29 pm
Got to agree about the proportions - the leggies and glove box look as of they were manufactured like that.
Great thread.....
Postby LateAgain » Tue Jan 12, 2016 1:58 am
Noddabodder wrote:Great build, I really like the proportions on this. What exhaust/engine configuration are you planning?
Hoping for an iron 247 with DJ copy pipe. 71 bore 62 crank. Got the barrel but no crank yet. It's an old Kawasaki conversion barrel and I've got a Wossner H2 piston to fire in there. Motor is a long way off yet!
Thanks for the rest of the comments. ;)
LateAgain
Postby Adam_Winstone » Thu Jan 14, 2016 7:53 pm
Nice work... but please promise me that you'll fit the top beading end-caps the other way around (screw heads seen from the inside) when you build it for real?
Ta :)
Postby LateAgain » Thu Jan 14, 2016 8:50 pm
Really? Hold my ignorant hands up to that one. Thankfully no room for a chequered flag on leggies. Adam, you are Mr GP in OCD. I promise to turn em around if we can make a date for transfer timing on your 62 crank. ;)
LateAgain
Postby Digger » Fri Jan 15, 2016 9:08 am
LateAgain wrote:Really? Hold my ignorant hands up to that one. Thankfully no room for a chequered flag on leggies. Adam, you are Mr GP in OCD. I promise to turn em around if we can make a date for transfer timing on your 62 crank. ;)
Not having owned a GP I did a quick trawl on Google - of the pictures with large enough resolution to see there's a lot more out there using the same orientation as yourself... ;)
Digger
Postby duncan1958 » Fri Jan 15, 2016 12:34 pm
May I ask what you did to the leg shield beading/rubbers to get them to fit and stay there ?
Did you cut the wavey part out of the inside of the rubber ?
duncan1958
Postby Adam_Winstone » Fri Jan 15, 2016 1:07 pm
This should be the same orientation on all Innocenti SIIIs but I've noted SIL GPs having plastic beading caps the 'wrong' way around. Whilst this link takes you to a Rimini restored GP/DL, the photos are very clear as to which way they should go. If you struggle to see the screw ends from the front, have a look at the clear photo of the ignition switch / back of headset, in which you can very clearly see the screw heads...
http://www.riminilambrettacentre.com/en ... tail/id/59
... nearly as frustrating as GP flag being 180 or 90 degrees out! ;)
Postby Digger » Fri Jan 15, 2016 1:13 pm
:D
Digger
Postby Nigel. S » Fri Jan 15, 2016 5:52 pm
thinking out loud...... could you fit some sort of deflector plate behind the toolbox vents to divert any rainwater from electrics and put a drain hole in bottom of toolbox?
Nigel. S
Postby LateAgain » Fri Mar 04, 2016 12:30 am
duncan1958 wrote:May I ask what you did to the leg shield beading/rubbers to get them to fit and stay there ?
Hello Duncan, I haven't done anything to the inside of the beading. I was going to weld some strips to edge of leggies to hold beading on but I've gone off that idea, don't wanna fcuk the shape up with my poor welding... gonna silicon them on now.
LateAgain
Postby LateAgain » Fri Mar 04, 2016 12:34 am
Nigel. S wrote:thinking out loud...... could you fit some sort of deflector plate behind the toolbox vents to divert any rainwater from electrics and put a drain hole in bottom of toolbox?
Could be a plan, left the toolbox alone for a bit now. Might revisit later or just go with it.
LateAgain
Postby LateAgain » Fri Mar 04, 2016 5:18 pm
Bit of progress on GSC...
Welded up some old holes and cut some new cable slots
Quick Action throttle, needs a polish up
Mocking up rear light position, not a lot of room on back end
Making up no plate holder
Starting prep work on leggies, they're a bit battered. Getting feckin dusty in the garage now. Endless filling and sanding.
Popped a couple of extra leggy supports on, one would have been enough for the Vega leggies previously intended
TBC... :roll:
LateAgain
Postby duncan1958 » Fri Mar 04, 2016 8:00 pm
Hi ,Yes I was going to cut and alter the bits of the leg shields that I cut off mine but came to the conclusion that the amount of work involved could not be justified for the net result. in other words a waste of time :)
I have just pushed on regular uncut beading for the time being although it will need some glue.
duncan1958
Postby duncan1958 » Fri Mar 04, 2016 8:06 pm
Oh looking good by the way.
You have about as much room to work in your garage as me at the moment .
Drag some sheets off the beds to cover the rest of your fleet up from dust,just be careful when you start grinding or welding ;)
duncan1958
Postby LateAgain » Fri Mar 04, 2016 10:09 pm
^^^ set light to some wire wool t'other day grinding off welds. Took me by surprise out of corner of eye!
LateAgain
Postby duncan1958 » Sat Mar 05, 2016 12:19 pm
LateAgain wrote:^^^ set light to some wire wool t'other day grinding off welds. Took me by surprise out of corner of eye!
There are better ways to raise your heart rate !
I have a rule of not welding anything for an hour before shutting up shop .
duncan1958
Users browsing this forum: No registered users and 56 guests
