30mm dellorto banjo fitting
Postby Granty » Fri May 29, 2015 9:00 am
Troops, got a 30mm delly running open mouth but I think the fuel line is catching on the side of the panel and knocking the carb of the MB rubber, can I turn the banjo around so the fuel inlet is pointing down the way so the fuel pipe doesn't run along the the inside of the panel? Carb is defo not touching the panel and stationary the carb is tight on the rubber and manifold. Any ideas this fine Friday morning? Cheers and have a good day y'all - G
Granty
Re: 30mm dellorto banjo fitting
Postby johnnyXS » Fri May 29, 2015 9:45 am
fine eh !? :roll: its dark and squally here in Somerset . :(
There is adequate 'head' of pressure from the tank to feed the carb so I would expect the banjo to flow perfectly whatever angle it is set at so long as the fuel line doesn't kink.
Might be worth searching for a better clamp to prevent the carb popping out of the rubber inlet or potential air leaks. Maybe one with a narrower band
Send some of that fine weather down here will'ya :lol:
johnnyXS
Postby Granty » Fri May 29, 2015 11:52 am
johnnyXS wrote:fine eh !? :roll: its dark and squally here in Somerset . :(
I'll try a narrow clamp -- it popped of the manifold side, the rubber was defo fitted in the groove properly -- see what tonight brings - G
Granty
Postby johnnyXS » Fri May 29, 2015 12:10 pm
I read somewhere recently about modding the spigot to prevent the carb popping off. Think it was on the MB Development site or maybe Camlam.
johnnyXS
Postby Norrie Bodge » Fri May 29, 2015 10:03 pm
johnnyXS wrote:I read somewhere recently about modding the spigot to prevent the carb popping off. Think it was on the MB Development site or maybe Camlam.
you meaning last months Oilyrag feature
Jetset Issue-195 ?
Norrie Bodge
Postby johnnyXS » Fri May 29, 2015 11:30 pm
Ahhhh thats where I saw it :roll: :lol:
strewth if my memory gets any worse .............:oops:
johnnyXS
Return to Carburettors
Users browsing this forum: Google [Bot] and 64 guests
