Italian GP/DL 125, 150, 200 & Electronic
Need specific detail for a particular model, or just found something strange and interesting and want to know if its original. All attention to detail seekers report here!
Strict no chatter
Re: Italian GP/DL 125, 150, 200 & Electronic
Postby Stypevince » Fri Mar 06, 2015 6:33 pm
Thanks for your reply.
By the way did you check you frame number ? is it close of mine ?
Cheers,
Vince
Stypevince
paint codes for italian gp200
Postby rudeboy67 » Mon Mar 09, 2015 4:29 am
Please could some one tell me the correct codes for all the colours on a gp200 yellow ochre ,silver and white All the colours in picture below and a good source to order from Thanks
[imgImage][/img]
rudeboy67
Postby Dimitrios_231 » Mon Mar 09, 2015 3:31 pm
carlos fandango wrote:Has anyone got a port map or port timings for a std italian gp200 barrel , they could share please?
I have a gp200, the barrel is 66mm with untouched ports , it has the two cutouts on the top fin, so its either gp or sx /jet afaik, it also had a 10mm ish cast circle with a dimple in the middle of it by the inlet, i just want conformation that it is. Gp barrel as the engine has been rebuilt at some stage with some sx parts ?
ThanksRuss
This is the port map,of an Italian 66mm barrel.
It has the two nocthes at top fin,
it is untuned and marked '3' or '8',sorry I can't remember.
I don't know if it is a SX or GP barrel as it was removed from a TV200 crankcase.
It was running with a TV200 center squish head.
This is the barrel
Top right
Dimitrios_231
Postby carlos fandango » Fri Mar 13, 2015 1:03 am
Thanks for posting that Dimitrios, its identical to mine :) trouble is , you'er not sure if its an SX or a GP either ?? :?
carlos fandango
Postby wurzel » Sun Mar 15, 2015 2:54 am
Stypevince wrote:Thanks for your reply.
Cheers,
Vince
My late 1970 GP 200 has the bracket to take the black plastic flap and has a black plastic toolbox,horn grill and rear grill,
frame number 2574XX.
My 1969 GP 200 has metal flap,horn grill, rear grill (painted) and grey plastic toolbox.
From my understanding this was the only way these parts were fitted and of the ones I've come across, including the 125/150 models
this is the only way I've seen them arranged.
Regards Mark
wurzel
Re: paint codes for italian gp200
Postby Paul Slack » Tue Apr 07, 2015 9:24 pm
rudeboy67 wrote:Please could some one tell me the correct codes for all the colours on a gp200 yellow ochre ,silver and white All the colours in picture below and a good source to order from Thanks
Lechler Auto Paints main web site has a list of european suppliers and there is generally one nearby. Lechler supplied the original paint and still have the codes on file. I got mine from the sheffield authorised supplier. Try these guys for your local supplier:
Lechler Coatings Ltd.
MANCHESTER
Unit 42, Pochin Way
Middlewich Cheshire
CW100GY United Kingdom
Tel. +44(0) - 1606 - 738.600
Fax +44(0) - 1606 - 738.517
lechler.uk@lechler.eu (lechler.uk@lechler.eu)
All you require is the Lechler code:
Ochre is 8080 for a start.
Paul Slack
Postby Dimitrios_231 » Tue Apr 21, 2015 9:08 pm
Last Sunday I did a 150 miles trip using the 'red' LIMS Futa rear shocker,it replaced a modern S3 Casa-Carbone (right),
the old shocker is miles better,I was shocked :)
I searched more into some old used stuff that I have and found another LIMS Futa-Felsina,both LIMS (center) measure more than 310mm is this normal for GP models?
The red one is a little longer.
Dave Webster's tuning manual says that it is better to use a longer rear shocker for better clearance.
Where can I get replacement outer bushes for original rear shockers?
Has anyone ever tried Escorts (left) bushes on older shockers?
Dimitrios_231
Postby LateAgain » Sat Apr 25, 2015 9:49 am
Can anyone confirm or deny if a GP/DL125 used an S3 air box as standard for the 20mm carb. Bought the set shown below and not sure if they below together or not!
LateAgain
Postby Paul Slack » Tue Apr 28, 2015 12:51 pm
What part numbers are on them? Include API or IGM numbers
Paul Slack
Postby LateAgain » Tue Apr 28, 2015 11:19 pm
Cheers Paul...
IGM 2105 S. Airbox
19 91 6018. Elbow
LateAgain
Postby Paul Slack » Thu May 07, 2015 2:04 pm
No problem mate.
Those numbers are exactly matching S3 Li125 parts.
Paul Slack
Postby wurzel » Mon May 18, 2015 2:44 pm
Hi folks , I'm trying to find someone who stocks the rivets used to hold the anchor points
in the GP plastic toolboxes as I want to remove mine to have them re-plated.
I seem to remember there was someone on here who removed their's while restoring a GP
but I can't find the thread.
Cheers in advance
wurzel
Postby A64yorkie » Mon May 18, 2015 7:38 pm
on the subject of horn grill my 1969 gp150 as it was in the 1973ish had a metal ali horn grill which it still has to day but the rear frame grill was plastic because it got knacked with nitromorse when it got painted (hot stuff) grey plastic tool box tho . the colours new were horncasting and side panels red the rest white with black strips. but am told if correct lambretta in London would add the red for UK market any comments Yes I know its an innocent disc brake etc a scrapped an SX200 to get that in 1982 and make it into a GP200 !!! photo last summer
A64yorkie
Postby Dimitrios_231 » Wed May 20, 2015 2:03 pm
I found a standard original S3 SCM rear shocker (center),it is 30cm eye to eye
Left LIMS Felsina-Futa,center SCM 671025 S,right LIMS Futa
Dimitrios_231
Postby TurboTrev » Wed May 20, 2015 2:08 pm
^^^Dimitrios - how do you get the LIMS version apart, as shown above? Thanks.
TurboTrev
Postby Dimitrios_231 » Wed May 20, 2015 3:03 pm
I believe this pic will help you ;)
Dimitrios_231
Postby TurboTrev » Wed May 20, 2015 3:22 pm
^^ Thanks. 8-)
TurboTrev
Postby TurboTrev » Thu Jun 04, 2015 5:42 pm
Did original grey toolbox GPs have the battery sticker on the toolbox or the petrol tank. If I remember rightly I'm pretty sure it was on the toolbox, but cannot find a photo of an unrestored GP to back up my memory. Can anyone confirm? Thanks.
TurboTrev
Postby hullygully » Fri Jun 05, 2015 10:20 am
I've got a picture from the old forum that shows the white battety sticker on the toolbox, if I can find it.. :?
Postby nickw » Fri Jun 05, 2015 10:27 am
Not sure if I have the right answer but along time ago on here there was a lengthy discussion about this because of the black toolboxes used later on and therefore would you see the black writing. I seem to remember that your thoughts are correct though and that the sticker was placed on the toolbox.
nickw
Return to Anorak's Corner
