carlos fandango wrote:Has anyone got a port map or port timings for a std italian gp200 barrel , they could share please?
I have a gp200, the barrel is 66mm with untouched ports , it has the two cutouts on the top fin, so its either gp or sx /jet afaik, it also had a 10mm ish cast circle with a dimple in the middle of it by the inlet, i just want conformation that it is. Gp barrel as the engine has been rebuilt at some stage with some sx parts ?
ThanksRuss
Stypevince wrote:Thanks for your reply.
By the way did you check you frame number ? is it close of mine ?
Cheers,
Vince
rudeboy67 wrote:Please could some one tell me the correct codes for all the colours on a gp200 yellow ochre ,silver and white All the colours in picture below and a good source to order from Thanks
