The Wossner pistons from af are decent and for a wossner they aint that expensive.
dscscotty wrote:The Wossner pistons from af are decent and for a wossner they aint that expensive.
And they come in .25 increments, Jap pistons are a great alternative, however many of them require an 18mm small end so may need a rod change, not to mention a the head re-profiling, Oh and welcome to the minefield and many hours of searching piston/rod specs.
Is it still possible / viable of safe to have brass bushes in the piston to make rod choice simpler? cheers,Speedy.
Knowledge wrote:I recall that Harry Barlow had sourced some 116mm rods with an 18mm small-end. He considered them the holy grail of Lambretta con-rod (no, they weren't, Ape rods)
Eden wrote:The Wossner pistons from af are decent and for a wossner they aint that expensive.
Users browsing this forum: Google [Bot] and 24 guests
