ts1 piston
ts1 piston
Postby lammy57 » Mon Jun 16, 2014 6:21 pm
Hi going to have my ts1 steel lined and was wondering what piston to use ? mb,beedspeed ,ron moss ,asso any thoughts just looking for pros and cons
lammy57
Re: ts1 piston
Postby Scooterlam » Mon Jun 16, 2014 9:01 pm
if you want a Ron Moss piston I would hurry up :) they're going fast.
Scooterlam
Re: ts1 piston
Postby Toddy » Tue Jun 17, 2014 6:22 am
Ive ran and run the Ron Moss type piston also the cheaper Beedspeed one but changed the rings on it for the Riken ones, both have been fine
Re: ts1 piston
Postby speedy » Tue Jun 17, 2014 8:49 am
If your having it lined, wouldn't you be better using a Jap type piston as opposed to the graded type pistons such as the Asso. Do the a,b,c and d grades go out as far as a rebore piston if it was needed?Having said that, the latest Asso RB/TS1 piston is really good then there is Harry Barlow[Pro Porting] who does his Pro piston which used 1mm top quality rings. cheers ,Speedy
speedy
Re: ts1 piston
Postby mickyb » Tue Jun 17, 2014 11:38 am
why don't you ask the guy who's doing the reline?
mickyb
Re: ts1 piston
Postby soullad » Tue Jun 17, 2014 1:48 pm
as Speedy says the true benefit of a steel liner is the fact that you now have the option of simply reboring and going again, on and on so to speak, so building your set-up around a piston choice with plenty of oversizes would make sense in the long run?
It also allows you to alter the porting layout a little, so pistons with rings that previously may have dropped in and out of the boost port for example can now be considered too, simply by moving the boost port over a touch.
But all of the above is only worth doing if you choose a quality piston with quality rings, otherwise whats the point? The recent batch of new TS pistons from Asso, Ron, Harry, MB etc have somewhat lessened the need for Jap piston conversions BUT if its good enough for the big Jap 4 then its good enough for a Lammy IMHO.
Choose the best you can afford.
soullad
Re: ts1 piston
Postby dscscotty » Tue Jun 17, 2014 6:51 pm
The Wossner pistons from af are decent and for a wossner they aint that expensive.
And they come in .25 increments, Jap pistons are a great alternative, however many of them require an 18mm small end so may need a rod change, not to mention a the head re-profiling, Oh and welcome to the minefield and many hours of searching piston/rod specs. ;)
Re: ts1 piston
Postby soullad » Tue Jun 17, 2014 11:04 pm
and don't forget to order an extra set of rings, gap them, and keep them as spares in your toolbox ;)
soullad
Re: ts1 piston
Postby speedy » Wed Jun 18, 2014 1:43 pm
Is it still possible / viable of safe to have brass bushes in the piston to make rod choice simpler? cheers,Speedy.
speedy
Re: ts1 piston
Postby gaz_powell » Wed Jun 18, 2014 5:12 pm
now theres a debate
I have a set on the shelf !!
Gaz
Re: ts1 piston
Postby Knowledge » Wed Jun 18, 2014 7:32 pm
I recall that Harry Barlow had sourced some 116mm rods with an 18mm small-end. He considered them the holy grail of Lambretta con-rod (no, they weren't, Ape rods)
Re: ts1 piston
Postby dscscotty » Wed Jun 18, 2014 8:19 pm
I've got some 16x22x18@115
You could but they can be problematic, tend to wear or break.
Re: ts1 piston
Postby Simon ELC » Fri Jun 20, 2014 10:58 pm
I always used to favour MB forged but had a few problems with ring pegs disappearing and the bottom ring gumming up. Having said that the last one has been great. However, my last build has the standard TS1/RB 1mm ring piston supplied by AF as recommended by a well known sprinter tuner.
Simon ELC
Re: ts1 piston
Postby soullad » Fri Jun 20, 2014 11:38 pm
Knowledge wrote:I recall that Harry Barlow had sourced some 116mm rods with an 18mm small-end. He considered them the holy grail of Lambretta con-rod (no, they weren't, Ape rods)
yep, Yamamoto parts if I recall.
Ape rods are 110 x 18 mm, and you have to grind your own lubricating slot into the big end eye. Worth the trouble thou as these are quality rods.
Might be worth starting a new thread Martin, listing and asking for part numbers for all Jap conversion parts such as pistons, rods etc, to add to the sum of knowledge like ;)
soullad
Re: ts1 piston
Postby Scooterlam » Sun Jul 13, 2014 5:57 pm
Eden wrote:The Wossner pistons from af are decent and for a wossner they aint that expensive.
Anyone know if he has 66mm in stock.
Scooterlam
Re: ts1 piston
Postby Scooterlam » Fri Jul 18, 2014 6:25 pm
Just got a ts piston off Ron for my current build,
Same make and quilty as the one in my avanti,
9k miles no issue .
£50 at the,moment, happy days.
Scooterlam
Users browsing this forum: Google [Bot] and 20 guests
