I'm guessing that's to be used with big end shims.monument7 wrote:Got one here measures 22.9, 28.9, 13,6
Scooterslag wrote:could you get away using a 22x28x16 bearing on a LI/SX crank?
dickie wrote:Scooterslag wrote:could you get away using a 22x28x16 bearing on a LI/SX crank?
You wouldn't be able to get it on the crank pin.
dickie wrote:I'm guessing that's to be used with big end shims.monument7 wrote:Got one here measures 22.9, 28.9, 13,6
What crank did it come off Dave?
monument7 wrote:dickie wrote:I'm guessing that's to be used with big end shims.monument7 wrote:Got one here measures 22.9, 28.9, 13,6
It came in a con rod kit I was going to put in my S2 crank which was siezed but being cheap the quality is @@@@, get what ya pay for so just bought a decent GP crank and con rod.
Gonna make me own con rod just to see what it turns out like and pick up another GP crank with big end gone to build up for my Special
made a start
