whats the size of a lambretta big end bearing?
Postby Scooterslag » Thu Jan 29, 2015 6:58 pm
as above, just being curious, sizes for LI/SX and GP if anyone knows - cheers Paul
Re: whats the size of a lambretta big end bearing?
Postby gaz_powell » Thu Jan 29, 2015 9:02 pm
From memory
Standard Innocenti LI to GP Italian were 22.9x28x16
Then came aftermarket cranks, SIL GP etc at 22x28x16 - which is now the most common
Postby Scooterslag » Thu Jan 29, 2015 9:43 pm
That's great, thanks for the information. Paul
Postby monument7 » Thu Jan 29, 2015 10:31 pm
Got one here measures 22.9, 28.9, 13,6
monument7
Postby Scooterslag » Thu Jan 29, 2015 11:43 pm
could you get away using a 22x28x16 bearing on a LI/SX crank?
Postby dickie » Fri Jan 30, 2015 12:26 am
monument7 wrote:Got one here measures 22.9, 28.9, 13,6
I'm guessing that's to be used with big end shims.
What crank did it come off Dave?
Postby dickie » Fri Jan 30, 2015 12:28 am
Scooterslag wrote:could you get away using a 22x28x16 bearing on a LI/SX crank?
You wouldn't be able to get it on the crank pin.
Postby Scooterslag » Fri Jan 30, 2015 12:32 am
ah yeah, very true, that's a shame as I've got a good condition SX crank that came out of a reliable motor of mine years ago and I foolishly didn't store it away properly and some of the rollers have rust spots on them. Just needs a new bearing as there is hardly any wear on the rod (0.20)
Postby monument7 » Fri Jan 30, 2015 1:12 am
It came in a con rod kit I was going to put in my S2 crank which was siezed but being cheap the quality is @@@@, get what ya pay for so just bought a decent GP crank and con rod.
Gonna make me own con rod just to see what it turns out like and pick up another GP crank with big end gone to build up for my Special
made a start Image
monument7
Postby HxPaul » Fri Jan 30, 2015 9:34 am
made a start Image
That conrod looks a bit thick,make sure it fits between the webs of a GP crank.
Postby monument7 » Fri Jan 30, 2015 12:47 pm
Yes it is thick because this is only half of the profile cut off on the saw. I have made a jig to sit this in to finish the other side down to thickness.
I used the conrod I got in the kit as a sample but not sure if this was a good example so might borrow a better quality one to copy. I know it seems a waste of time and I'm only doing it because I can not because I need to.
monument7
Postby dscscotty » Fri Jan 30, 2015 2:18 pm
Some bearing dimensons are also 22x29x16 some AF,MEC UR types use these dimension bearing as are indian GP200 rod/bearings.
Regards
Scotty
Users browsing this forum: Google [Bot] and 56 guests
