Side casing dowels
Side casing dowels
Postby alex_hughes » Thu Mar 12, 2026 3:01 pm
Standard dowels are typically 15mm long.
On the engine I’m working on they protrude 4mm when fitted
I’m fitting a Uni side casing which has a chamfer to ‘lead in’ the dowel.
Seems to me that there will be very little location when fitted.
Is there any reason why I shouldn’t fit longer dowels to improve location?
Or does it not matter as long as they are in the right place however little contact is made?
Thank you
Alex
alex_hughes
Re: Side casing dowels
Postby alex_hughes » Thu Mar 12, 2026 10:52 pm
I can comfortably fit 25mm long dowels. So that’s what I will do. Sadly the cheapest supplier is in China. Would have preferred local but that’s modern life I guess.
alex_hughes
Postby gaz_powell » Fri Mar 13, 2026 12:08 am
I know that feeling... Had to get some stainless shims for the rear of vespa drive side bearing.. Couldn't find them in UK... Coppers from China and delivered quickly.
Postby LambrettaMarky » Fri Mar 13, 2026 10:21 am
You could perhaps buy a length (300mm typically) of Silver Steel from eBay & make your own.
LambrettaMarky
Users browsing this forum: Google [Bot] and 24 guests
