gaz_powell wrote:Uni or SR/SIL all the way
Toddy wrote:I’ve used both BGM and SIL no issues with either
missing lynx wrote:I like the SIL ones but it can be a lottery getting genuine ones
dickie wrote:I've taken my s2 out after full rebuild and it's pretty much unridable. The vibration is unbelievable.
I thought it may have been caused by the head cowl touching the right hand side footboard. So I removed the footboard and went for a short run; no better.
The vibration is really bad. Could it really be just the small engine mounts that I've used?
It has a 62/110 crank which mighg be adding to the vibration, but not enough for this.
The last time I rode on old small type mounts must have been a standard one in the 80s but surely they weren't this bad?
Any ideas?
Toddy wrote:
Was there a reason you fitted small ones ? I would think if your running a non standard set under it may be an issue just my thoughts though
Storkfoot wrote:missing lynx wrote:I like the SIL ones but it can be a lottery getting genuine ones
CamLam![]()
The Scootopia ones, as long as you can guarantee it is one of the later ones, are good. I did have one set which should have been later softer ones which patently weren’t though.
