Cuts out on tickover when warm
Postby rogscoot » Wed Nov 19, 2014 10:05 am
Hi, my standard series 2 li150 starts to cut out when warm at tickover engine speed, it's fine when the revs increase and I'm actually going along but happens when I pull up to a junction or roundabout and have to stop, it's starts up straight away again.
Is it likely to be the condenser giving up on me? It's been replaced fairly recently but that's not to say that I didn't heat it up too much when fitting or that it's faulty out of the packet!
Thanks,
Rog
rogscoot
Re: Cuts out on tickover when warm
Postby Toddy » Wed Nov 19, 2014 1:02 pm
Are you sure its not just your Tickover Screw or Cable adjustment ?
Postby stonerosesmod » Wed Nov 19, 2014 1:52 pm
Or mixture screw may need adjusting with the colder weather?
stonerosesmod
Postby rogscoot » Wed Nov 19, 2014 3:40 pm
Yeah it's definitely not the tickover, the tickover speed is fine and I've tried adjusting the mixture screw but that doesn't seem to make any difference, what's the recommended amount of turns out? I've got it at 2 turns out at the minute and it's an Indian SPACO carb.
rogscoot
Postby bigbthesoulman » Fri Nov 28, 2014 5:51 pm
choke staying on
bigbthesoulman
Postby rogscoot » Mon Dec 01, 2014 10:15 am
I think I managed to fix this yesterday, it was the mixture screw - I've got it set to 3/4 turn out and it's not stalling on tickover now, hurrah!
rogscoot
