Engine number identification.
Postby kevspeed » Sun Jun 11, 2023 4:03 pm
Hi all, i have a Li 125 engine casing, number 125Li 563027 and im trying to find out what year scooter it was from. If i go by 'frame' numbers it says 1959 but it has the chamfer around the drive bearing which i thought was later on. Also i have a casing stamped 150 Li 767498, and again using 'frame' numbers its way out of scope as this casing doesnt have the chamfer on the drive bearing which made me think series 1 early 2 :?:
kevspeed
Re: Engine number identification.
Postby Littlewheels » Sun Jun 11, 2023 6:16 pm
Littlewheels
Postby kevspeed » Thu Jun 15, 2023 7:29 am
Littlewheels wrote:Try looking on here.......https://scooterlounge.com/lambretta/ref ... utch%20arm.
Interesting site... still none the wiser, no big deal really, i just thought it would be interesting to see how old the engines were.
kevspeed
Postby hullygully » Thu Jun 15, 2023 8:52 am
kevspeed wrote:Hi all, i have a Li 125 engine casing, number 125Li 563027 and im trying to find out what year scooter it was from. If i go by 'frame' numbers it says 1959 but it has the chamfer around the drive bearing which i thought was later on. Also i have a casing stamped 150 Li 767498, and again using 'frame' numbers its way out of scope as this casing doesnt have the chamfer on the drive bearing which made me think series 1 early 2 :?:
they are way out bud :shock: , dont take this the wrong way but could the casings be Indian?
the 150LI seams to be in the SX150 range & 125LI seams to be in the 150LI range :shock:
Rich should be able to confirm your queries bud ;)
Postby kevspeed » Sun Jun 18, 2023 9:14 am
Pretty sure that they are Italian and the number stamps dont look as they have been tampered with as far as i can see.
ImageIMG_20230618_084920_HDR by Kevin Payne, on Flickr
ImageIMG_20230618_084905_HDR by Kevin Payne, on Flickr
ImageIMG_20230617_090505_HDR by Kevin Payne, on Flickr
ImageIMG_20230618_084805_HDR by Kevin Payne, on Flickr
ImageIMG_20230618_084749_HDR by Kevin Payne, on Flickr
kevspeed
Postby nickw » Sun Jun 18, 2023 11:01 am
I had a memory about the engine numbers beginning with 7 and a quick check on BLA has this info ' Engine: Li150 or 150Li* followed by numbers starting from 500,001
*Note: Information has been found that shoes that some of the engine numbers started with a 7. Also the frame prefixes have been found to be stamped either Li150 or 150Li
http://www.britishlambrettaarchive.co.u ... nfo-2.html
hth a little
nickw
Postby Rich Oswald » Sun Jun 18, 2023 12:33 pm
Casings look Italian but the LI150*767498* looks re-stamped.
Postby kevspeed » Sun Jun 18, 2023 3:50 pm
Rich'[/quote]
Ok.......what about the 125 ?
kevspeed
Postby Rich Oswald » Sun Jun 18, 2023 9:02 pm
kevspeed wrote:Casings look Italian but the LI150*767498* looks re-stamped.
Ok.......what about the 125 ?[/quote]
The 125 looks ok
Postby kevspeed » Fri Jun 23, 2023 6:48 am
The 125 looks ok[/quote]
8-) Thank you 8-)
kevspeed
Postby Covboy » Wed Dec 24, 2025 3:30 pm
Hello
Could anyone through any light on this engine number- ?
*150LI*798582*
i.e. is it likley to be the correct engine for a 1966 li150 Golden Special (150LIS263175) ?
TIA
Users browsing this forum: No registered users and 94 guests
