Littlewheels wrote:Try looking on here.......https://scooterlounge.com/lambretta/ref ... utch%20arm.
kevspeed wrote:Hi all, i have a Li 125 engine casing, number 125Li 563027 and im trying to find out what year scooter it was from. If i go by 'frame' numbers it says 1959 but it has the chamfer around the drive bearing which i thought was later on. Also i have a casing stamped 150 Li 767498, and again using 'frame' numbers its way out of scope as this casing doesnt have the chamfer on the drive bearing which made me think series 1 early 2
hullygully wrote:kevspeed wrote:Hi all, i have a Li 125 engine casing, number 125Li 563027 and im trying to find out what year scooter it was from. If i go by 'frame' numbers it says 1959 but it has the chamfer around the drive bearing which i thought was later on. Also i have a casing stamped 150 Li 767498, and again using 'frame' numbers its way out of scope as this casing doesnt have the chamfer on the drive bearing which made me think series 1 early 2
they are way out bud, dont take this the wrong way but could the casings be Indian?
the 150LI seams to be in the SX150 range & 125LI seams to be in the 150LI range
Rich should be able to confirm your queries bud
IMG_20230618_084920_HDR by Kevin Payne, on Flickr
IMG_20230618_084905_HDR by Kevin Payne, on Flickr
IMG_20230617_090505_HDR by Kevin Payne, on Flickr
IMG_20230618_084805_HDR by Kevin Payne, on Flickr
IMG_20230618_084749_HDR by Kevin Payne, on Flickrkevspeed wrote:hullygully wrote:kevspeed wrote:Hi all, i have a Li 125 engine casing, number 125Li 563027 and im trying to find out what year scooter it was from. If i go by 'frame' numbers it says 1959 but it has the chamfer around the drive bearing which i thought was later on. Also i have a casing stamped 150 Li 767498, and again using 'frame' numbers its way out of scope as this casing doesnt have the chamfer on the drive bearing which made me think series 1 early 2
Pretty sure that they are Italian and the number stamps dont look as they have been tampered with as far as i can see.IMG_20230618_084920_HDR by Kevin Payne, on Flickr
kevspeed wrote:Casings look Italian but the LI150*767498* looks re-stamped.
Rich Oswald wrote:kevspeed wrote:Casings look Italian but the LI150*767498* looks re-stamped.
Ok.......what about the 125 ?
