Af clo5e box
Af clo5e box
Postby Psychedelicropcircle » Sat Jun 10, 2023 12:54 pm
Hi folks anybody using or recommend using 1st gear shims that are below 1mm?
Have the two under rear bearing shims in. Thick & thin! Suppose I could pull it all apart & put the double thick shims under the rear bearing. Thoughts team?
Save me from a new east to fit cyclone box please :lol:
Re: Af clo5e box
Postby Psychedelicropcircle » Sun Jun 11, 2023 12:45 pm
Update two x thick shim & 1x thin shim under rear bearing. Still too much for a 1mm shim.
:o
Using an MB layshaft.
Anybody with the same setup?
Euro fast approaching
Re: Af clo5e box
Postby hullygully » Mon Jun 12, 2023 9:01 am
some cyclone shims are less than 1mm bud
Re: Af clo5e box
Postby steveg » Mon Jun 12, 2023 5:34 pm
AF do or at least did shims at various thicknesses under 1mm, worth calling them maybe
steveg
Re: Af clo5e box
Postby hullygully » Tue Jun 13, 2023 1:29 pm
check the rear hub bearing's thickness dimensions against an old Innocenti one, I had a good 0.5mm differance on one bearing to std :shock:
Re: Af clo5e box
Postby hullygully » Tue Jun 13, 2023 1:32 pm
steveg wrote:AF do or at least did shims at various thicknesses under 1mm, worth calling them maybe
be careful with some of the AF's gear shims as they're not the same thickness in 4 x different positions on the outside diameter :?
I'd use cyclone or Broady :geek:
Re: Af clo5e box
Postby Psychedelicropcircle » Thu Jun 15, 2023 5:08 pm
When you say gear shims do you mean the the first gear shim or the wire under the bearing type?
Re: Af clo5e box
Postby bolzenanker » Fri Jun 16, 2023 9:01 am
I think Cyclone shims go down to 0.8mm, but I thought the AF box required a shim of between 1.4 and 2.4mm? (Could be wrong, going from memory.)
bolzenanker
Re: Af clo5e box
Postby hullygully » Fri Jun 16, 2023 11:31 am
Psychedelicropcircle wrote:When you say gear shims do you mean the the first gear shim or the wire under the bearing type?
1st gear shim bud
