4th gear issue
4th gear issue
Postby shane BBoys » Wed May 05, 2021 8:55 pm
Evening.
I finally got a chance to take the S2 for her maiden run: I couldn’t get 4th any ideas? There seams plenty of room between the rear and the gear selector arm!
Cheers Shane.
shane BBoys
Re: 4th gear issue
Postby al pushpak » Thu May 06, 2021 9:36 am
2/3/4th gear cable too tight ?
al pushpak
Re: 4th gear issue
Postby bookertmgs1 » Thu May 06, 2021 10:12 am
Have you checked that the gear arm is on the shaft on the correct spline ? Should level up to the side case stud when in 2nd gear. I had same issue and found out I was a spline out when I started to investigate. Was certain it was correct when I assembled the engine.
Assume that the gear housing had free movement at headset when assembled.
Checked back brake cable routing
bookertmgs1
Re: 4th gear issue
Postby missing lynx » Thu May 06, 2021 12:31 pm
Have you used a new tie rod? As some are the wrong length eye to eye
Re: 4th gear issue
Postby shane BBoys » Thu May 06, 2021 2:07 pm
missing lynx wrote:Have you used a new tie rod? As some are the wrong length eye to eye
Yes it is a new 1 I’ll check the length.
Cheers Shane.
shane BBoys
Re: 4th gear issue
Postby shane BBoys » Thu May 06, 2021 2:08 pm
bookertmgs1 wrote:Have you checked that the gear arm is on the shaft on the correct spline ? Should level up to the side case stud when in 2nd gear. I had same issue and found out I was a spline out when I started to investigate. Was certain it was correct when I assembled the engine.
I’ll check all the above.
Cheers Shane.
shane BBoys
Re: 4th gear issue
Postby shane BBoys » Thu May 06, 2021 2:09 pm
al pushpak wrote:2/3/4th gear cable too tight ?
Thanks I’ll check.
Cheers Shane.
shane BBoys
Re: 4th gear issue
Postby Toddy » Thu May 06, 2021 7:54 pm
Try selecting the gears without cables connected by hand see if you can get them all
Re: 4th gear issue
Postby Covboy » Thu May 06, 2021 8:54 pm
I had this once . I had thought I’d selected neutral between 1st and second when setting up the cables / handle bar selector, but I’d found a false neutral between 2nd and 3rd. When I thought I was in first , it was actually 2nd and I couldn’t get as far as 4th .
Re: 4th gear issue
Postby shane BBoys » Fri May 07, 2021 5:57 pm
Today’s findings:
The selector arm was 2mm in difference, so I removed the coating from with the trunnion hole, I removed the rear wheel and while the bike was on the engine prop I gingerly kicked her over, it stayed pretty firm so I pulled the clutch in with the left and operated the gear arm with the right, and found all the gears, I popped her in neutral and put the wheel back on and re- cabled the selector, I’ll try over the weekend hopefully all your answers have got me where I need to be.
Muchos
shane BBoys
Users browsing this forum: Google [Bot] and 88 guests
