Evening.
I finally got a chance to take the S2 for her maiden run: I couldn’t get 4th any ideas? There seams plenty of room between the rear and the gear selector arm!
Cheers Shane.
missing lynx wrote:Have you used a new tie rod? As some are the wrong length eye to eye
bookertmgs1 wrote:Have you checked that the gear arm is on the shaft on the correct spline ? Should level up to the side case stud when in 2nd gear. I had same issue and found out I was a spline out when I started to investigate. Was certain it was correct when I assembled the engine.
Assume that the gear housing had free movement at headset when assembled.
Checked back brake cable routing
al pushpak wrote:2/3/4th gear cable too tight ?
Users browsing this forum: No registered users and 84 guests
