Liberty - 1961 series 2 LI 125
Re: Liberty - 1961 series 2 LI 125
Postby soullad » Thu Oct 16, 2014 3:46 pm
Matt
PM me your address and I'll send you something that will help with the engine rebuild ;)
Ian
soullad
Postby pazwaa » Thu Oct 16, 2014 6:29 pm
soullad wrote:Matt
Ian
Cheers Ian, pm sent. ;)
pazwaa
Postby pazwaa » Sun Oct 19, 2014 5:28 pm
Found it Toddy, but thanks for the reminder :lol:
Better do some reading!!
Photo of the finished workshop/kids playhouse/storage facility
Hopefully get it back early next year and bring Liberty home ;) meanwhile engine off Tuesday.
pazwaa
Postby Toddy » Sun Oct 19, 2014 5:32 pm
Happy days ;) liking the workshop
Postby pazwaa » Wed Oct 22, 2014 12:59 pm
Had a sucsessful evening yesterday, got the frame fully stripped.
This is a beginners guide, any of you experience guys want to add comments/suggestions, feel free. ;)
Took this off first - is it a coil?
You can just make out the two screws to remove.
Next i removed all the cables. These were in a bad way, so getting binned.
Cables on the top of the engine
These were loosened with an allan key
Cable at the back of the engine, undo the nut and remove
Image[/URL
Unclip this wire
[URL=http://s1064.photobucket.com/user/pazwaa/media/Liberty/F3693647-21F4-465B-993B-D196BD817386.jpg.html]Image
Removed the kickstart, undo the bolt and slide off
Next remove the shocker. undo the two nuts and tapped off using a hammer shaft
Next undo the nuts holding the engine pivot bar
once the nuts were removed, this came out with some light taps of a hammer, firstly on one of the nuts to protect the threads, then using a socket extension through the frame
And the engine drops. Move it out of the way.
Next remove the rear brake pedal. Release the spring, undo the grease nipple and slid off
These are the removed components
Then i removed the headlight, just a couple of screws. Remove the electrical connection block. Remove the two screws holding the top of the headset
A few photos of the interanls of the headset. i removed all cables
Next remove the bolt holding the headset to the forks, you can see it part removed here
and removed
Remove the headset and your left with this
You really need special tools to remove the nuts holding the forks, but a gentle tap with a chisel loosened the top once and a large c-spanner removed the second
Remove the forks
To remove the front wheel you undo the nuts, then knock out two washers recessed into the forks. these
and the wheel drops out
Next i removed the stand, undo a bolt for each bracket. Remember to undo the spring
Components removed
Thats it, frame stripped, took about 2 hours
frame
Either strip the engine or sort the panels out next.
any comments/suggestions most welcome ;)
cheers
matt
pazwaa
Postby Rich Oswald » Wed Oct 22, 2014 6:52 pm
Fantastic detailed and comprehensive strip down. Thank you and very well done indeed,
Postby duncan1958 » Wed Oct 22, 2014 9:36 pm
Well detailed strip down will help you no end when it comes to the rebuild stage.
I would go with the panels next.
The mantra here would be...
Dry build
Dry build
Dry build.
Not wishing to insult however if you dont know this phrase ,its put ALL the panels on ,get your gaps and fitment right before getting any paintwork done.
Do not assume that the panels will fit nicely no matter how good a condition they may be in.
Enjoy.
duncan1958
Postby pazwaa » Wed Oct 22, 2014 10:30 pm
Rich Oswald wrote:Fantastic detailed and comprehensive strip down. Thank you and very well done indeed,
Cheers Rich. Hopefully it will help others out a bit at some point.
Matt
pazwaa
Postby pazwaa » Wed Oct 22, 2014 10:37 pm
duncan1958 wrote:Well detailed strip down will help you no end when it comes to the rebuild stage.
Dry build
Dry build
Dry build.
Enjoy.
Cheers Duncan
Yep, took lots of photos whilst stripping down and everything bagged and labelled, so hopefully the rebuild will run smoothly (ish)! ;)
Dry build is a good call. Need to get the frame blasted first, bit of welding on the panels then ready for a test build. Would you primer the panels before a dry build, or leave them bare metal?
pazwaa
Postby dickie » Sun Oct 26, 2014 4:41 am
Toddy wrote:It will tell you all you need to know just about fella , just hope you find it :lol: :lol:
It won't tell you to fit a o-ring to your layshaft before you build your gearbox. You will realise just after you've finished the whole bloody thing! :cry:
Postby lambrettatastic » Sun Oct 26, 2014 11:31 am
If you are wanting to do a proper job,then the rear mudguard will need to come off,as well as the chrome ring on top of the fork tube,and the bearing race at the bottom.
lambrettatastic
Postby pazwaa » Sun Oct 26, 2014 7:07 pm
Dickie, please remind me of this in two years time when I rebuild everything :D
Matt
pazwaa
Postby pazwaa » Sun Oct 26, 2014 7:08 pm
lambrettatastic wrote:If you are wanting to do a proper job,then the rear mudguard will need to come off,as well as the chrome ring on top of the fork tube,and the bearing race at the bottom.
I've taken the rear mudguard off, but forgot about the chrome ring and bottom bearing race :( thanks for the heads up, will get them removed.
Matt
pazwaa
Postby duncan1958 » Sun Oct 26, 2014 9:34 pm
pazwaa wrote:Dry build is a good call. Need to get the frame blasted first, bit of welding on the panels then ready for a test build. Would you primer the panels before a dry build, or leave them bare metal?
I would advise some form of rust protection,bare metal can start to oxidize very quickly even from the touch of bare hands/sweaty palms :o
If the panels are going to need some work getting straight then go with a light coat of primer although its not water proof as such is way better than bare metal,then where repairs are needed it can be wiped off easily with thinners or sanded down.
duncan1958
Postby pazwaa » Sun Nov 02, 2014 9:34 am
Thanks Duncan, much appreciated ;)
pazwaa
Postby pazwaa » Sun Nov 02, 2014 9:49 am
This week was fork stripping, and it didn't go very well :oops:
First removed the hinge bolts and rubber stop bolts.
All were easy apart from one hinge bolt, this one
Tried tapping it from the inside with the nut on, but it deformed. Cut the head off the other side and tried tapping it the other way, wouldn't budge. Eventually I drilled a small pilot hole in the end so I could get a centrepunch tip located and it came out, very,very slowly :?
Next I struggled to get the fork links out, with the Pistons still locating in the fork cup. They came out eventually with too much force being applied by me, so the pistons got bent :oops:
Should I have used a fork compression tool?
Anyway, the forks are now stripped, need to strip the paint, then a bit of fabrication for some shocker mounts next.
Are the fork rebuild kits on ebay any good? Or anyone recommend a good place to but replacement parts?
Matt
pazwaa
Postby duncan1958 » Sun Nov 02, 2014 10:21 pm
Not supprised you bent the rods :o
You will need a spring compressor to reassemble for sure.
On the old forum a fellow memeber made his own and posted the diagram on here,I believe it was reposted when the system was up and running again.
I bought one of the spring compressors and had to modifiy it to work to my satisfaction,had I have seen the one I am talking of posted I would have made one.
duncan1958
Postby pazwaa » Sun Nov 02, 2014 10:41 pm
duncan1958 wrote:Not supprised you bent the rods :o
Thanks Duncan ;) yeah, rookie error, gonna buy a set of proper lambretta tools before the rebuild, including a spring compressor :oops:
Will look for the homemade one too.
Matt
pazwaa
Postby pazwaa » Wed Nov 05, 2014 1:35 pm
Little bit of bodywork last night
first to address was the hole in the panel
now you see it
now you dont (sorry, terrible photo :shock: )
then wirewheeled the top of the headset
now a request. could someone send me a photo of the inside of an italian side panel. mine are indian, so need to know what i need to modify. also can anyone point me in the direction of how to mod my forks and lugs to accomodate shockers?
thanks
matt
pazwaa
Postby Nigel. S » Wed Nov 05, 2014 8:47 pm
Somehow missed this so just read whole thing from start. Great read. Always good to read these DIY rebuilds. Good luck with it.
From my own experience only, I would pay a bit more and buy decent components for forks rather than a "rebuild kit". ones I had were woefully bad. Holes off centre through bushes, nuts/bolts with unsymetrical heads, just complete sh1te, but as I say that was my experience. It is tough if you're on a budget and you are confronted with a cheap option for something that costs double elsewhere. But there will normally be a good reason why prices are so different. Hope that helps, don't mean it to be a downer. ;)
Washers, believe it or not the lower ones were what was in the kit, top ones innocenti originals, guess which I used. And the dealer told me on the phone that they check all the components of their kits, check for what I wonder! Also balls on end of rods were wrong size (despite ordering kit with small balls :shock: ) and didn't fit snug into fork links and look like they'd been made with a blunt plastic spoon! Maybe it was just my choice of dealer that was the prob, can't remember who without going through receipts but hey, I'm over it now :lol:
Anyhow, keep at it. Great thread :D
Nigel. S
Users browsing this forum: No registered users and 60 guests
