Tino disc
Tino disc
Postby John Deeley » Fri Jun 19, 2020 6:55 pm
Has anyone got one of Tinos hydra semi hydraulic front discs in use, would you recommend it?
John Deeley
Re: Tino disc
Postby ULC Soulagent » Sat Jun 20, 2020 8:32 am
No, fecking rubbish
ULC Soulagent
Re: Tino disc
Postby John Deeley » Sat Jun 20, 2020 11:47 am
ULC Soulagent wrote:No, fecking rubbish
Don't beat about the Bush. :lol: :lol:
John Deeley
Re: Tino disc
Postby Storkfoot » Sat Jun 20, 2020 12:56 pm
Have a read of this too. I bought an old Campagnolo one after reading the responses to this.
viewtopic.php?f=10&t=12209
Re: Tino disc
Postby ULC Soulagent » Sat Jun 20, 2020 3:12 pm
You did ask :D
ULC Soulagent
Re: Tino disc
Postby Psychedelicropcircle » Mon Jun 22, 2020 3:39 pm
I also have a club mate that endlessly bitches about how shite this is.
Re: Tino disc
Postby dickie » Mon Jun 22, 2020 4:28 pm
The disc has a better recess for the anti rattle clip than the spaq ones. Sits a little deeper and allows the disc to fl float more freely.
Someone had to say something positive.
Re: Tino disc
Postby Storkfoot » Tue Jun 23, 2020 8:52 am
I used the actual Tino disc itself on a reverse pull Campagnolo hub set up a few years back. I found the disc improved the efficiency of the brake significantly. They have no circlip and have drilled holes.
When I get to road test the current original set up I have built, if the old disc itself doesn’t inspire confidence, I shall buy one of Tino’s Evergreen ones.
Re: Tino disc
Postby Mr G in NYC » Fri Jul 03, 2020 6:55 pm
Yeah I got two and I like them 8-)
G
Re: Tino disc
Postby Andy B.L.C. » Fri Jul 03, 2020 9:42 pm
More words please Graham...
Andy B.L.C.
Re: Tino disc
Postby dickie » Sat Jul 04, 2020 12:47 pm
Storkfoot wrote:I used the actual Tino disc itself on a reverse pull Campagnolo hub set up a few years back. I found the disc improved the efficiency of the brake significantly. They have no circlip and have drilled holes.
That's odd. The one I bought last year did have an anti rattle clip but was significantly looser than a standard one. Made the brake much better.
Re: Tino disc
Postby Storkfoot » Sat Jul 04, 2020 2:16 pm
Pinched from the SCK website. This is the Tino one that, from my personal experience running it on a reverse pull set up, I was recommending.
Re: Tino disc
Postby Chadley » Sat Jul 04, 2020 3:08 pm
Storkfoot wrote:Pinched from the SCK website. This is the Tino one that, from my personal experience running it on a reverse pull set up, I was recommending.
Did you get any rattle with this one if it doesn't have the circlip?
Chadley
Re: Tino disc
Postby Storkfoot » Sat Jul 04, 2020 7:45 pm
You get a tiny bit when pushing the scooter before starting but, after that, as long as you reasonably regularly put a smear of copper grease on the 3 pins, they are fine. The same can be said for any disc without the circlip in my experience.
Users browsing this forum: Baidu [Spider] and 37 guests
