ULC Soulagent wrote:No, fecking rubbish
John Deeley wrote:ULC Soulagent wrote:No, fecking rubbish
Don't beat about the Bush.![]()
Storkfoot wrote:I used the actual Tino disc itself on a reverse pull Campagnolo hub set up a few years back. I found the disc improved the efficiency of the brake significantly. They have no circlip and have drilled holes.
When I get to road test the current original set up I have built, if the old disc itself doesn’t inspire confidence, I shall buy one of Tino’s Evergreen ones.
Storkfoot wrote:Pinched from the SCK website. This is the Tino one that, from my personal experience running it on a reverse pull set up, I was recommending.
Chadley wrote:Storkfoot wrote:Pinched from the SCK website. This is the Tino one that, from my personal experience running it on a reverse pull set up, I was recommending.
Did you get any rattle with this one if it doesn't have the circlip?
Users browsing this forum: Google [Bot] and 55 guests
