Toddy wrote:Wont be the springs they are all pretty much standard strength it will be the panel fit or the rear bracket , are they re made panels ?
MickYork wrote:Go to a gym
missing lynx wrote:Have you checked the bar moves freely on the rod if you remove the spring if it's not then that could be the problem
Watfordwhite wrote:Could be the rubbers on the legs, if too wide the push the panel out to much making it much harder / impossible to secure the panel arm
HxPaul wrote:My s1 is the same,its very hard to put the panels on.Say you put the right hand panel on,I've found that if you put the panel on and hit it hard on the bend to make sure its on correctly and push down directly above the panel handles,turning the handle at the same time,the handle will turn easier.
Ranburetta wrote:Try using a Birmingham screwdriver!
holty wrote:ive just rebuilt a series 2 which has the same handles, what I did to make the handle easier to turn was the split pins that hold the springs on I bent them like a c shape so the springs are not under so much tension, I then bent the end of the split pin around the opposite way to hold it in place, I also used the brass end caps which improved the job.
Users browsing this forum: Bing [Bot] and 66 guests
