S1 Panel Handles
S1 Panel Handles
Postby Rich Oswald » Wed Aug 07, 2019 8:19 am
Ok so the S1 I have just got on the road, I have serious trouble getting the panel handles clipped into place. I have to lie down on floor and compress the springs and pull them back. Basically the springs are just too strong. I don't want to do anything which might compromise the panel security (ie: risk panel coming off). I have a JB conversion on the left side which has slight adjustment but that doesn't help.
Any ideas?
Re: S1 Panel Handles
Postby Toddy » Wed Aug 07, 2019 12:17 pm
Wont be the springs they are all preety much standard strength it will be the panel fit or the rear bracket , are they re made panels ?
Postby Rich Oswald » Wed Aug 07, 2019 1:49 pm
Toddy wrote:Wont be the springs they are all pretty much standard strength it will be the panel fit or the rear bracket , are they re made panels ?
Original panels and bracket at one side is slightly adjustable but makes no difference. Do you think I should file the curve of the bracket slightly?
Postby Digger » Wed Aug 07, 2019 6:12 pm
Can't you shorten the springs a little to ease the pressure?
I'd be very reluctant to start trimming the brackets - they've probably worked for the last 60 years or so.
Digger
Postby MickYork » Wed Aug 07, 2019 7:38 pm
Go to a gym :shock:
Postby Rich Oswald » Wed Aug 07, 2019 8:30 pm
MickYork wrote:Go to a gym :shock:
.I've been expecting an answer like this. Well after five shoulder op's, that's not possible but even so they shouldn't be this hsrd to turn. I've had loads before but none this hard.
Postby missing lynx » Wed Aug 07, 2019 11:05 pm
Have you checked the bar moves freely on the rod if you remove the spring if it's not then that could be the problem
Postby Watfordwhite » Wed Aug 07, 2019 11:09 pm
Could be the rubbers on the legs, if too wide the push the panel out to much making it much harder / impossible to secure the panel arm
Watfordwhite
Postby HxPaul » Thu Aug 08, 2019 8:17 am
My s1 is the same,its very hard to put the panels on.Say you put the right hand panel on,I've found that if you put the panel on and hit it hard on the bend to make sure its on correctly and push down directly above the panel handles,turning the handle at the same time,the handle will turn easier.
Postby Rich Oswald » Thu Aug 08, 2019 8:35 am
missing lynx wrote:Have you checked the bar moves freely on the rod if you remove the spring if it's not then that could be the problem
Yep the bar moves freely.
Watfordwhite wrote:Could be the rubbers on the legs, if too wide the push the panel out to much making it much harder / impossible to secure the panel arm
It was the same before I fitted the rubbers.
HxPaul wrote:My s1 is the same,its very hard to put the panels on.Say you put the right hand panel on,I've found that if you put the panel on and hit it hard on the bend to make sure its on correctly and push down directly above the panel handles,turning the handle at the same time,the handle will turn easier.
I will give this a go.
Thanks all,
Postby Ranburetta » Thu Aug 08, 2019 4:47 pm
Try using a Birmingham screwdriver!
Ranburetta
Postby Rich Oswald » Fri Aug 09, 2019 10:04 am
Ranburetta wrote:Try using a Birmingham screwdriver!
Had to Google it but a very big hammer WOULD suffice, lol. :lol: :lol: :lol:
Postby holty » Sun Aug 11, 2019 9:06 am
ive just rebuilt a series 2 which has the same handles, what I did to make the handle easier to turn was the split pins that hold the springs on I bent them like a c shape so the springs are not under so much tension, I then bent the end of the split pin around the opposite way to hold it in place, I also used the brass end caps which improved the job.
holty
Postby Rich Oswald » Sun Aug 11, 2019 11:22 am
holty wrote:ive just rebuilt a series 2 which has the same handles, what I did to make the handle easier to turn was the split pins that hold the springs on I bent them like a c shape so the springs are not under so much tension, I then bent the end of the split pin around the opposite way to hold it in place, I also used the brass end caps which improved the job.
Good call, I will have a look at that, thanks.
Users browsing this forum: No registered users and 59 guests
