Have the two under rear bearing shims in. Thick & thin! Suppose I could pull it all apart & put the double thick shims under the rear bearing. Thoughts team?
Save me from a new east to fit cyclone box please
steveg wrote:AF do or at least did shims at various thicknesses under 1mm, worth calling them maybe
Psychedelicropcircle wrote:When you say gear shims do you mean the the first gear shim or the wire under the bearing type?
