PM me your address and I'll send you something that will help with the engine rebuild
Ian
soullad wrote:Matt
PM me your address and I'll send you something that will help with the engine rebuild![]()
Ian
[/URL
Rich Oswald wrote:Fantastic detailed and comprehensive strip down. Thank you and very well done indeed,
duncan1958 wrote:Well detailed strip down will help you no end when it comes to the rebuild stage.
I would go with the panels next.
The mantra here would be...
Dry build
Dry build
Dry build.
Not wishing to insult however if you dont know this phrase ,its put ALL the panels on ,get your gaps and fitment right before getting any paintwork done.
Do not assume that the panels will fit nicely no matter how good a condition they may be in.
Enjoy.
Toddy wrote:It will tell you all you need to know just about fella , just hope you find it![]()
dickie wrote:Toddy wrote:It will tell you all you need to know just about fella , just hope you find it![]()
It won't tell you to fit a o-ring to your layshaft before you build your gearbox. You will realise just after you've finished the whole bloody thing!
lambrettatastic wrote:If you are wanting to do a proper job,then the rear mudguard will need to come off,as well as the chrome ring on top of the fork tube,and the bearing race at the bottom.
pazwaa wrote:Dry build is a good call. Need to get the frame blasted first, bit of welding on the panels then ready for a test build. Would you primer the panels before a dry build, or leave them bare metal?
duncan1958 wrote:pazwaa wrote:Dry build is a good call. Need to get the frame blasted first, bit of welding on the panels then ready for a test build. Would you primer the panels before a dry build, or leave them bare metal?
I would advise some form of rust protection,bare metal can start to oxidize very quickly even from the touch of bare hands/sweaty palms![]()
If the panels are going to need some work getting straight then go with a light coat of primer although its not water proof as such is way better than bare metal,then where repairs are needed it can be wiped off easily with thinners or sanded down.
duncan1958 wrote:Not supprised you bent the rods![]()
You will need a spring compressor to reassemble for sure.
On the old forum a fellow memeber made his own and posted the diagram on here,I believe it was reposted when the system was up and running again.
I bought one of the spring compressors and had to modifiy it to work to my satisfaction,had I have seen the one I am talking of posted I would have made one.
