Engine mounts - comfort
Postby TrackTen » Mon Jul 14, 2025 4:44 pm
I need to fit some new engine mounts - I am more interested in comfort than race track performance but would also like them to last a sensible amount of time.
My choices are
The latest Scootopia type
BGM
Or the latest Uni type
Any recommendations for my needs ?
TrackTen
Re: Engine mounts - comfort
Postby nsaints » Mon Jul 14, 2025 5:08 pm
A couple of years ago i had a strange vibration on the GP around 50 mph which cleared above 55mph, after a rebuild
Tried all the usual suspects nothing
In the end solved it by swapping out the new BGM mounts with some unbranded/SIL ones from scooter restorations.
As i said a couple of years ago. Maybe BGM are OK now?
nsaints
Postby gaz_powell » Wed Jul 16, 2025 9:26 pm
Uni or SR/SIL all the way
Postby Rich Oswald » Thu Jul 17, 2025 9:29 am
gaz_powell wrote:Uni or SR/SIL all the way
+1
Postby TrackTen » Thu Jul 17, 2025 1:38 pm
Thanks for the replies
TrackTen
Postby Toddy » Thu Jul 17, 2025 4:01 pm
I’ve used both BGM and SIL no issues with either
Postby Rich Oswald » Fri Jul 18, 2025 9:52 am
Toddy wrote:I’ve used both BGM and SIL no issues with either
+1
Postby missing lynx » Sat Jul 19, 2025 2:23 pm
I like the SIL ones but it can be a lottery getting genuine ones
Postby Storkfoot » Sat Jul 19, 2025 3:42 pm
missing lynx wrote:I like the SIL ones but it can be a lottery getting genuine ones
CamLam :idea: :)
The Scootopia ones, as long as you can guarantee it is one of the later ones, are good. I did have one set which should have been later softer ones which patently weren’t though.
Postby dickie » Tue Jul 22, 2025 8:34 pm
I've taken my s2 out after full rebuild and it's pretty much unridable. The vibration is unbelievable.
I thought it may have been caused by the head cowl touching the right hand side footboard. So I removed the footboard and went for a short run; no better.
The vibration is really bad. Could it really be just the small engine mounts that I've used?
It has a 62/110 crank which mighg be adding to the vibration, but not enough for this.
The last time I rode on old small type mounts must have been a standard one in the 80s but surely they weren't this bad?
Any ideas?
Postby Toddy » Tue Jul 22, 2025 8:43 pm
dickie wrote:I've taken my s2 out after full rebuild and it's pretty much unridable. The vibration is unbelievable.
Any ideas?
Was there a reason you fitted small ones ? I would think if your running a non standard set under it may be an issue just my thoughts though
Postby dickie » Tue Jul 22, 2025 8:55 pm
Just to keep original looks. I know it's under the panels but you know what lambretta owners are like :lol:
I'll change the mounts if I have to, but I wanted thoughts on whether that was likely to be the cause before I rush in.
I really want this ready for ripon, but can't ride it there like this.
Postby TrackTen » Mon Jul 28, 2025 1:08 pm
CamLam :idea: :)
Ta - might try the Scootopia ones then - I had some of the first hard ones years back and those were horrendous
TrackTen
Postby gaz_powell » Tue Aug 05, 2025 7:43 pm
Just bought another set of Uni for next motor.
Im happy with the two sets ive fitted and using to go for more
Users browsing this forum: No registered users and 104 guests
