citydaz wrote:Hi,
the MOT guidelines are here:
https://www.mot-testing.service.gov.uk/ ... s/class12/
"Direction indicators aren’t needed for motorcycles that:
don’t have front and rear position lamps
have front and rear position lamps permanently disconnected, painted over or masked
can’t exceed 30mph / 50kph
was first used before 1 August 1986
are ‘off road’ motorcycles designed to carry only the rider
are ‘off road’ motorcycle combinations designed to carry the rider and one passenger in the side car"
The logic implies that if you mask over your headlight and rear light, then you dont need to have indicators. In an earlier section on headlights it says they are needed on motorbikes unless they are masked over, in which case they cant be tested.
It seems daft, but thats what it says!
Users browsing this forum: Baidu [Spider] and 69 guests
