Rear Shocker slight leak re MOT
Postby St George » Tue Feb 19, 2019 5:25 pm
Will moisture around the chrome shaft fail the MOT Test or will it be an advisory, thanks.
St George
Re: Rear Shocker slight leak re MOT
Postby Digger » Tue Feb 19, 2019 5:50 pm
As long as it's not oil you should be ok. Usually get that on my Bandit as it seldom gets used over winter and as luck would have it MOT is due.
My tester just wipes it off.
Digger
Postby citydaz » Tue Feb 19, 2019 9:53 pm
Why would they remove the sidepanel to see this?
my MOT tester has never removed a sidepanel.
citydaz
Postby Fast n Furious » Wed Feb 20, 2019 12:34 am
citydaz wrote:Why would they remove the sidepanel to see this?
Engine mountings, Rear suspension and Rear wheel assembly are all part of the MOT check. A lot easier to do with the panels off.
Postby missing lynx » Wed Feb 20, 2019 12:09 pm
My mot-er never removes my side panels as long as you take your v5 along for the frame number mind you this is why it pays to use the same mot station so they get to know you
Users browsing this forum: No registered users and 94 guests
