td bank atm machine near me
coaster wrote:That last idea would have too much flex to provide sufficient brake travel I suspectIt would work better if the pivot pin was removed and replaced with a steel tube and the relocated pedal modified to have a spindle welded that would rotate in the new tube. Some way of mounting the rear part of the old pedal on the other end of the new spindle would be required but this would allow the cable to work as per normal. Or consider hydraulic?
St George wrote:Would it be possible to fit hydraulic to the back and front and operate both from the front handlebar lever with a larger reservoir for the brake fluid . There must be a way to send 60% of the force to the front brake for correct braking. We have been doing this on cars for many years.
Users browsing this forum: No registered users and 35 guests
