dscscotty wrote:increasing the stroke can increase torque, but as stated port timing/duration do need to be considered, many fit base packers thinking the longer stroke requires it, when infact it would be better to remove material from the base to lower the cylinder to bring back port durations to a more conservative opening period. as stated can have a negative affect on performance if not done correctly.
ToBoldlyGo wrote:dscscotty wrote:increasing the stroke can increase torque, but as stated port timing/duration do need to be considered, many fit base packers thinking the longer stroke requires it, when infact it would be better to remove material from the base to lower the cylinder to bring back port durations to a more conservative opening period. as stated can have a negative affect on performance if not done correctly.
Interesting stuff. I have a 60 X 110 crank in a TV engine case. It's got a Casa 185 kit with a packer at the base and it's pretty flat to be honest. It only seems to come in well up the revs. I presume this is exactly the sort of thing you're talking about? Sounds to me as if the cylinder needs to be lowered. Do you add it at the top?
superhooper wrote:Flipping hell, I'm lost. I'll stick to 58/107
Knowledge wrote:Paul, I have already put my phone on silent.
Martin
