5I by Billy Bongo, on FlickrThe ability to post messages is restricted to LCGB members. Any questions contact us at lcgbadmin@googlemail.com
solostax wrote:Thank you for posting photo of your Jet 200,
I needed an example to build mine from just the bare frame up. However I notice yours has a louvered tool box lid whereas this area on mine is solid, uncut and doesn't form a lid.
Gathering what info I can from Stickys and adverts etc, I'm filtering through the various parts I've acquired over the years to fit the most appropriate parts to get the scooter close to its original factory configuration.
In this endeavour your picture replaces a thousand words.
Regarding differences between series 3 LI and the Jet,.. are the front mudguard, rear light housing, rear floor panels, petrol tank the same?
Would appreciate learning any other deviations from Innocenti specification.
Best regards.
solostax wrote:Thanks Northern Jordan and ToBoldlyGo for your advice.
Just to confirm..I have a recent LCGB dating cert that gives it as a Jet 200 1982.
So far I've managed to aquire and fit a stand (with different spring attachment point on frame),forks with fat dampers ,rear mudguard ,SX headset and F/G servetta horncast. in the process of a dry build I've offered up tatty series 3 legshields that seems to fit.
This project was never intended to be a 100% reincarnation of an original ,and so I will have to compromise somewhat.In this I'm trying to balance cost with an acceptable "Bitser" with the ongoing option of replacing non original with pukka parts when and if available.
Thanks for your Facebook tip, and if for the purpose of serving others interest ,can post pictures of my progress.
Truly appreciate your help.
Regards
3M by Billy Bongo, on Flickr
3L by Billy Bongo, on Flickr
5R by Billy Bongo, on Flickr
5N by Billy Bongo, on Flickr
5Ped by Billy Bongo, on FlickrUsers browsing this forum: Majestic-12 [Bot] and 90 guests
