lozmondo wrote:The way the Gt exhaust port is cast if you catch your down pipe on a kerb/spped hump etc you can pull the studs out of the cast
Donnie on here had this happen.
so during your 10000 miles how many times have you changed the piston and or rings?burnside wrote:I run a GT186 kit in my workhorse scooter. Used for daily commute and rallies, did 1300 miles on the Euro last year, fantastic kit and coming up to 10k miles on it now with no issues what-so-ever.
My set up is 60/110 GT crank, Li150 16/46, PHBH30 and Fran Race, even though it loves to rev it happily plods along in rush hour traffic through the city as well. Will cruise at 60-65 all day long, and flat out have topped 80 (GPS) on several occasions.
Like others my reeds are doubled up and not had any breakage issues, but change them at the same time as piston rings just for piece of mind.
Scooterdude wrote:so during your 10000 miles how many times have you changed the piston and or rings?burnside wrote:I run a GT186 kit in my workhorse scooter. Used for daily commute and rallies, did 1300 miles on the Euro last year, fantastic kit and coming up to 10k miles on it now with no issues what-so-ever.
ToBoldlyGo wrote:Just as a note. I'm going for the GT in the end. It was a toss up between the two. The RT is literally plug and play, but it ought to be interesting setting up the GT. I suppose it's a bit more rock and roll.
