Chaincasing
Chaincasing
Postby Jim » Thu Nov 15, 2018 10:05 pm
I'm building an engine up and will be using a185 casa, my chain case cover is an early one with no reinforcing around the kick start, do I need the later one with reinforcing or will it be ok?
Jim
Re: Chaincasing
Postby HxPaul » Thu Nov 15, 2018 10:18 pm
I have two scooters with Casa 185's,one with the early chaincase cover and one with the later chaincase cover.They do have a lot of compression,but I'm happy to take the risk of the early chaincase cover breaking.Something you must bear in mind is,if you use the eary chaincase cover you must use a kickstart pedal to match,the same applies if you use a later chaincase cover.
Re: Chaincasing
Postby Jim » Fri Nov 16, 2018 10:11 pm
HxPaul wrote:I have two scooters with Casa 185's,one with the early chaincase cover and one with the later chaincase cover.They do have a lot of compression,but I'm happy to take the risk of the early chaincase cover breaking.Something you must bear in mind is,if you use the eary chaincase cover you must use a kickstart pedal to match,the same applies if you use a later chaincase cover.
Good point thanks for that info
Jim
Re: Chaincasing
Postby peejay » Sun Nov 18, 2018 10:01 am
hi Jim
i've run a 185 mugello kit for several years with a standard S2 sidecase with no problems at all.
shortly after fitting the kit the original kickshaft shaft twisted and jammed. a new one was strengthened with weld and is now fine.
i would be more worried about the kickstart shaft
PJ
Re: Chaincasing
Postby Jim » Sun Nov 18, 2018 5:44 pm
peejay wrote:hi Jim
PJ
Cheers peejay
Jim
Re: Chaincasing
Postby Jim » Mon Nov 19, 2018 10:04 am
Is there an upgraded kickstart shaft you can buy? What's the best folks?
Jim
Re: Chaincasing
Postby holty » Tue Nov 20, 2018 6:12 pm
I broke my kickstart shaft and casing trying to start my 290, it has got a lot of compression, I fitted a casa shaft and another sidecase and ive had no more problems, they were recommended to me by martin at chiselspeed and he ordered it for me, top man.
holty
Re: Chaincasing
Postby Jim » Tue Nov 20, 2018 8:09 pm
holty wrote:I broke my kickstart shaft and casing trying to start my 290, it has got a lot of compression, I fitted a casa shaft and another sidecase and ive had no more problems, they were recommended to me by martin at chiselspeed and he ordered it for me, top man.
Bril, cheers
Jim
Re: Chaincasing
Postby Raveydavey » Sun Nov 25, 2018 8:16 am
If it’s Italian, I’d stick with what you’ve got.
I’ve clocked a few thousand miles on a 1958 Franebreather, original kickstart shaft and casing on 26bhp quattrini. Still as good as new :D
Raveydavey
Users browsing this forum: No registered users and 38 guests
