7 stud mugello head
7 stud mugello head
Postby Martin s » Sat Nov 24, 2018 8:28 pm
I've got a large block mugello cylinder which is 4 stud, the head is 7 stud. Can this be used or would
it be like a colander?
Martin s
Re: 7 stud mugello head
Postby Knowledge » Sat Nov 24, 2018 9:24 pm
I’d say it could be used.
I assume that when you place the 7 hole head on top of the cylinder, you can’t see into the barrel through the vacant 3 holes....
Postby Martin s » Sat Nov 24, 2018 9:54 pm
I can see quite a bit of the gasket face through the 3 surplus holes is what's bothering me. I got it like this.
https://imgur.com/5XSCrvp
https://imgur.com/zSxb5TF
https://imgur.com/L1pmHYy
https://imgur.com/UPO4Abw
Martin s
Postby Knowledge » Sun Nov 25, 2018 9:42 pm
OK, that is pretty much what I was expecting to see. As long as there is a continuous band of ali head gasket around the top of the barrel (which there will be), then you should be fine.
Postby Martin s » Mon Nov 26, 2018 7:47 pm
Thanks Martin.
Martin s
Users browsing this forum: No registered users and 35 guests
