SIP speedo on Series 1 with hydrulic hose.
Postby HartleyHare » Fri Nov 23, 2018 6:15 pm
Help needed please. I'm trying to fit a SIP speedo on a S1. I've got a hydrulic hose running down into horncover on throttle side. I can't see any space now to get the extension cable up from power box into speedo body. Extension cable has a fairly big connector on end. Then there's the temp sensor cable too ...... anybody done this? Cheers.
HartleyHare
Re: SIP speedo on Series 1 with hydrulic hose.
Postby Toddy » Sat Nov 24, 2018 8:54 am
I swapped the standard nut from the headset clamp for a smaller nylock type this allows you more space to feed cables /wiring down the gap , I run my thumb choke cable through there
Postby HartleyHare » Sat Nov 24, 2018 2:07 pm
Thanks for reply Toddy. Yes good solution this also allows hydrulic hose though bolt hole on headset bottom. No need to drill headset now. Cheers Harvey
HartleyHare
Users browsing this forum: No registered users and 76 guests
