Knowledge wrote:Ok, I acknowledge the value of the comments in the last two posts. You both make good points. The principle of a heavy head sits comfortably with me.
Fast n Furious wrote:When I built my TS1/200, I had the head made to my own CAD specific design by Mito in Italy. The lingo translation was a bit iffy initially, but they were happy to make it to my specs.
Principally, its a standard dimensioned, aircraft grade billet ally, 7 point fixing, centre squish head.
Its uses a 10mm long reach extended nose plug, located in the usual place, at an angle where the spark gets generated smack centre of the combustion bowl for maximum combustion efficiency.
Trouble free performance for the last 6000 miles, Still running fine on the original plug. Well happy
ROClarke wrote:Will the BGM head go straight on after any adjustments for squish ?
hullygully wrote:A/F's also do a Mamoof head, loosely based I think on the Avanti, dowelled too.![]()
I put that on my TS1 245 & recently did the 4 x Nations, on motorways, all the way from Hull to Fermanagh & back, with NO heat issues.
Scooterdude wrote:I think there are two kinds of BGM heads, the drop in verity than come with the cylinder kit and have eight fixing points and the other ones for retro fit that fit flush with the top of the cylinder like a standard head with the standard four point fixing, both machined from billet but at £168 not cheap.
ROClarke wrote:Don't you need a different head cowl for the woolly mammoth storkfoot ?
Users browsing this forum: No registered users and 34 guests
