rear hub bearing
rear hub bearing
Postby terryj » Fri Jun 06, 2014 4:59 pm
is there a way to remove this bearing without going in through the gear box dont fancy a total strip down if i can avoid it
terryj
Re: rear hub bearing
Postby Nigel. S » Fri Jun 06, 2014 5:46 pm
Sure there was a method described on old forum, involved welding something onto bearing in order to pull it out. maybe someone will remember.
Or method described in old servicemans guides was to knock it through by hitting the other end of layshaft, but you'll be into strip down territory then.
Nigel. S
Postby JETEX » Sat Jun 07, 2014 2:04 am
There probably is a way, but when you knock the new bearing in, it could affect the clearances in the gearbox and you may have to re-shim it.
JETEX
Postby denisiw » Fri Jun 13, 2014 9:30 am
The rear hub bearing has a shoulder which locates on the INSIDE of the engine casing, therefore the clutch, gears etc have to be removed.
Sorry, wrong head on this morning! I meant to say that it was not possible to remove the bearing because it has to be knocked out from the INSIDE. Got you thinking though. I suddenly thought about it down the shed and thought I ought to correct what I'd written but someone beat me to it!
Apologies again.
Denis
denisiw
Postby Nigel. S » Fri Jun 13, 2014 11:01 am
^ is that correct?
Nigel. S
Postby lambypolo » Fri Jun 13, 2014 1:48 pm
No, the shoulder is effectively on the outside of the casing but the way it sits means it's nigh on impossible to remove it without taking the gearbox out.
lambypolo
Postby terryj » Fri Jun 13, 2014 5:31 pm
thanks for the replies bit the bullet and went in
good job too it was the end plate coming loose that was the problem not the bearing although i have changed it whilst i was in there
terryj
Postby denisiw » Fri Jun 13, 2014 6:22 pm
lambypolo wrote:No, the shoulder is effectively on the outside of the casing but the way it sits means it's nigh on impossible to remove it without taking the gearbox out.
I've corrected my post as below.
Apologies again.
Denis
denisiw
Postby Scooter Paul » Sun Jun 15, 2014 1:58 pm
terryj wrote:thanks for the replies bit the bullet and went in
For what it's worth and in the spirit of rebuilding the knowledge base I've never had a failed 'hub' bearing. A wobbly wheel has always (in my experience, others will have their opinions) been as a result of a worn bearing or layshaft end at the 'plate' end.
Paul
Scooter Paul
Postby Bristol Daz » Sun Jun 15, 2014 4:04 pm
I have to say, I'm with Scooter Paul on this, any problems I've had have always been endplate/layshaft bearing related!
Bristol Daz
Users browsing this forum: No registered users and 83 guests
