Two jets in one hole
Postby Knowledge » Sun Oct 21, 2018 10:15 pm
On my VHSH carb, the idle circuit has two jets in the one hole.
One sits in the bottom of the hole, and the other is the traditional location. The carb was supplied with a B45 at the bottom of the hole and a 60 idle jet.
Why two jets and why different sizes?
Re: Two jets in one hole
Postby ULC Soulagent » Mon Oct 22, 2018 10:03 am
Taken from Mb’s tech site
Flat slide Dellorto's have another jet under the idle jet called an air jet! I find it best to leave it in as standard, some dealers remove it! There is very little information to what or how to adjust this air jet. Removing the air jet effects jetting!
ULC Soulagent
Postby Knowledge » Mon Oct 22, 2018 10:57 am
Thanks.
I can tell that was written by MB, as there are an excessive number of exclamation marks. ;)
Does anyone have any other information?
Postby Toddy » Mon Oct 22, 2018 12:15 pm
Its called an Emulsion tube i think it allows a smaller pilot to be used above it , some take them out and fit a normal size pilot im sure someone a bit cleverer will be along to explain better ;)
Postby dickie » Mon Oct 22, 2018 1:59 pm
Knowledge wrote:Thanks.
He's always surprised isn't he? Like that woman on the Catherine Tate show. Very helpful despight the appawling punctuation and grammar.
Postby ULC Soulagent » Tue Oct 23, 2018 11:29 am
Contact eurocarb as that what I did when needing answers for the vhst flatslide that I was using.
Took them about a week too reply :?
ULC Soulagent
Return to Carburettors
Users browsing this forum: Bing [Bot] and 46 guests
