Rich Oswald wrote:I used one of these and found them ok,
http://www.skydrive.co.uk/proddetail.asp?prod=EP001%2FS
steveg wrote:As you may recall Martin I've run skydrive EGTs for a number of years and the probes are definitely a consumable item. Mine have all failed to zero when gone.
As an aside I haven't connected the one on 22 to my most recent exhaust and don't have one on Brian. As a result I've had a much more relaxed year of scootering not worrying about temps, maybe it's the future?
Scooterdude wrote:Mine always fracture were the spring connects to the sensor obviously being shook until it finally gives up the ghost and breaks off.
What I intend to do with my new one is to slide a piece of garden hose over were the spring is and fill the void with silicone sealant then wait until the silicone has cured then. Cut away the hose leaving a slug if silicone around the spring so hopefully should cure the breakages.
