by pg42 » Tue Oct 09, 2018 3:59 pm
Bought a project with a series 2 engine in it which had a sheared cush drive bolt. I replaced it and after shimming the gearbox, reassembled the motor. Fitted a 12 volt conversion. Trying to start it the following happens. With the spark plug fitted the engine turns over once or twice then the flywheel freewheels. Take the plug out and the engine turns over fine. Sort of thought it might be a clutch problem but it has freeplay so i'm not sure. Has anybody got any sensible suggestions please? This has me completely stumped. Cheers.
pg42
by Digger » Tue Oct 09, 2018 4:40 pm
Have you fitted the new cush drive bolt and tightened it correctly?
Sounds like the splines aren't aligned.
Digger
by HxPaul » Tue Oct 09, 2018 4:59 pm
Digger wrote:Have you fitted the new cush drive bolt and tightened it correctly?
+1
by Scooter Paul » Wed Oct 10, 2018 12:54 pm
It also sounds as if the flywheel woodruff key may have sheared.
Scooter Paul
by pg42 » Wed Oct 10, 2018 3:52 pm
Thanks for the advice. I have stripped and reassembled everything including the cush gear. Absolutely on splines but engine has the same problem. Could there be excessive wear on the cush gears? When i said the flywheel 'free wheels' i mean that all compression disappears and the flywheel remains almost stationary.
pg42
by HxPaul » Wed Oct 10, 2018 4:04 pm
pg42 wrote:Thanks for the advice. I have stripped and reassembled everything including the cush gear. Absolutely on splines but engine has the same problem. Could there be excessive wear on the cush gears? When i said the flywheel 'free wheels' i mean that all compression disappears and the flywheel remains almost stationary.
In that case it could be the clutch,it sounds like your clutch cable could be to tight.Disconnect your clutch cable from the clutch arm on top of the engine and try it kicking it again.
by pg42 » Wed Oct 10, 2018 6:56 pm
That was a thought at the start, but after reassembling this time, i left the clutch cable off. it does feel like a badly adjusted clutch but with the cable not connected, it cant be.
Kicking it over i get 2 good compressions then it slips.
pg42
by HxPaul » Wed Oct 10, 2018 7:45 pm
Are your clutch corks worn.They should fit(only just)between the jaws of an open ended 14mm spanner.
by kennystag » Fri Oct 12, 2018 8:35 am
Any news
kennystag
by pg42 » Fri Oct 12, 2018 3:21 pm
I am going to replace the clutch and see if that cures it. Wont be for a few days as i'm off on my hols.
pg42
by pg42 » Mon Nov 19, 2018 11:25 pm
New clutch-all good
pg42
Users browsing this forum: Baidu [Spider] and 81 guests
