Scooterdude wrote:Just considering the Readspeed 5 plate clutch at around £40. The engine is a MB tuned 235 rt with reed valve fitted, it produces 25bhp and 20 torques.
Just fitted 4 new surflex plates but still slipping as the engine climbs onto the pipe, dont really want to splash out £225 on an af 6 plate if i can get away with the £40 5 plate.
Thoughts and other opinions please.
Scooterdude wrote:Have also been looking at a clutch basket on the af site that takes 6 plates, six standard ones?? so im guessing if i get that and build it up the top plate will rub on the kick start arm?
Warkton Tornado No.1 wrote:Scooterdude wrote:
It's a shame that the ScootRS clutch with six plates is no longer available, though you could browse CamLam's site to see what you could squeeze in the standard, generic clutch centre & crownwheel.
corrado wrote:When I was selling the scootRS Atomic stuff I had a 46 crownwheel machined to drop the plates lower but it went through to thin air so I wasn't prepared to sell them like that as it was a potential weak spot. So I made some up using Italian Tutto crownwheels, which were around 80 quid, the problem was that 80 quid for a crownwheel, 50 quid for pressure plate, 50 quid for spider, 30 quid for plates and steels and 12 quid for MB springs made it as expensive as the AF road clutch so it was a no brainer in my opinion. A set of 5 BGM soft feel 2.6mm thin plates, mated to 3 x 1.2 steels and 1 x 1.5 steel with LTH uprated springs works out at about 36 quid.
